Media Offline??? No it isn't!!! at DVinfo.net
Final Cut Suite
Old October 21st, 2011, 07:11 PM   #1
As usual, I have ALL related files in one project folder. As I was accumulating png files I decided to create a sub folder (within the main folder) and it all went wrong from there.
I've dragged the png's back to the main folder where they were, I've deleted them and re-dragged them into the canvas bin, I've double clicked them in the timeline and seen the image in the viewer, but when the project is played any png's I had moved into the sub folder have been replaced by MEDIA OFFLINE.
I want to sling this laptop off my balcony.
Cameron Poole is offline   Reply With Quote
Old October 21st, 2011, 07:16 PM   #2
Re: Media Offline??? No it isn't!!!
FCP7 or FCPX?
Justin Molush is offline   Reply With Quote
Old October 21st, 2011, 07:59 PM   #3
FCP 7
Just did a Quicktime compression and the png's aren't there, got spinning media offline message instead.
I have put the SAME png files back where they were in the project file AND put them back/deleted/put them back into the browser.
Old October 22nd, 2011, 12:42 AM   #4
Make sure the original files are in the original place and OPEN a previously saved version of your project from the AUTOSAVE VAULT, specifically a version from a date/time prior to you making those folder changes.
Edward Mendoza, Videographer/Editor, TEXAS VIDEO PRODUCTION
www.texasvideoproduction.us
Edward Mendoza is offline   Reply With Quote
Old October 22nd, 2011, 01:38 AM   #5
It worked, for 90% of the render. The last split second still has the media offline logo.
Fortunately it wasn't a complicated keyframe, so I re-imported it from my external HD and changed it's name and imported it as a new file, deleting all evidence of the glitchy one.
Old October 22nd, 2011, 04:49 AM   #6
Look into "reconnect media" function on the right click menu. Once you tell fcp where one file is, it reconnect as many as possible ( there's a checkbox telling it to do that). It sounds like you might have imported them from an external hard disk by mistake thinking it was a local version that you had imported from. . Not sure but reconnect media would have solved the problem in less than a minute.
Old October 28th, 2011, 08:05 AM   #7
I've always had trouble with PNG's in Final Cut. I use Tiff or Jpgs
always learning
www.phillippalacios.com
Phillip Palacios is offline   Reply With Quote
Old October 28th, 2011, 08:39 AM   #8
Huh - that is really weird. I consistently use .PNGs in FCP7 and havent had the issue where it wouldn't recognize the .PNG, even after I have to scrounge across 2-3 external drives to find all the assets when I revisit projects after a year...
There must be something else going on - it is completely updated right?
Old October 29th, 2011, 11:41 AM   #9
Les is correct, reconnect media!
David W. Jones
www.joneshdfilms.com
David W. Jones is offline   Reply
