mp4 to .mov at DVinfo.net
Final Cut Suite
Old September 26th, 2011, 02:04 PM   #1
mp4 to .mov
footage was shot on a JVC gy-hm100 in mp4, "told jesse james i need it shot .mov!!
he didnt, how can i convert to .mov
thanks
john
John Doran is offline   Reply With Quote
Old September 26th, 2011, 02:09 PM   #2
Re: mp4 to .mov
Try MPEG Streamclip - it's free. BTW .mp4 is a kind of .mov.
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/
Rick L. Allen is offline   Reply With Quote
Old September 26th, 2011, 02:20 PM   #3
Re: mp4 to .mov
trying it now, is that the only way FCP will take mp4?
thanks
Old September 26th, 2011, 02:24 PM   #4
Re: mp4 to .mov
no good to jerky
Old September 26th, 2011, 03:21 PM   #5
Re: mp4 to .mov
Convert it to ProRes. mov describes the container, but you need a codec easier to edit than avchd (mp4) so go with ProRes.
Cheers,
GB
R Geoff Baker is offline   Reply With Quote
Old September 26th, 2011, 03:49 PM   #6
Re: mp4 to .mov
hi geoff
cheers what pro res? in PAL land here, there are a few
best
john.
Old September 26th, 2011, 04:06 PM   #7
Re: mp4 to .mov
If I read your question as 'which of the ProRes options should I use' the answer is I guess which ever one your hard drive can stand, but in truth you can't 'improve' from your source, so the ProRes 422 LT should be fine.
PAL or NTSC makes no difference here -- they are all the same codec, it is only the framerate that changes.
Cheers,
GB
Old September 27th, 2011, 01:37 AM   #8
Re: mp4 to .mov
ok geoff
will try that thanks
john
