Snow Leopard killed DVDSP at DVinfo.net
Final Cut Suite
Old September 26th, 2011, 12:19 PM   #1
A month or so after Lion came out, I decided Snow Leopard was probably mature enough. Since I was between important projects I went ahead and installed my upgrade. There were a couple of hiccups, but they were solved pretty quickly.
Today however, I discovered a huge problem. DVD Studio Pro will unexpectedly quit when I attempt to do almost anything at all with it. It opens fine. I can open old projects fine. But if I go to save, or import, etc. it will "unexpectedly" quit every time.
Googling has brought me little info and a lot of misinformation that's at least a year old in any case. Has anyone else run into this and were you able to solve it?
I'm running 10.6.8 on a 2 x 2.66 GHZ Dual-Core Xeon Mac Pro with 9GB RAM. I'm running DVDSP 4.2.2 which has run flawlessly on this machine for years prior to my move to Snow Leopard.
Since this started I have tried deleting preferences and receipts and re-installing DVDSP all to no avail.
Mark Warren is offline   Reply With Quote
Old September 26th, 2011, 01:59 PM   #2
Re: Snow Leopard killed DVDSP
Did you try removing it with this tool?
FCS Remover - Uninstall Final Cut Studio, Final Cut Pro, Motion, Compressor, Soundtrack Pro, Color, DVD Studio Pro, LiveType, Cinema Tools
If not, try that...
(maybe the whole studio)
I don't have any problems with DVD SP on Snow Leopard... On different machines (iMac, Mac Pro's at work, Macbook Pro's, ...)
Mathieu Ghekiere is offline   Reply With Quote
Old September 26th, 2011, 04:03 PM   #3
Beware of FCP Remover. You'll lose any FCP plugins you've accumulated over the years and you'll be left only with what's shipped in FCS3. That goes across the board... LiveType will be gone... favorites: gone ...so back up those things.
I'd post on Apple's discussion board before doing a clean install. Look in the Console right after the crash and post what's there from the crash on Apple's board too.
Old September 27th, 2011, 08:59 AM   #4
FCS Remover only removes the files you want to remove. You can selectively choose which components to uninstall or keep, including plugins.
Jon Chappell is offline   Reply With Quote
Old September 28th, 2011, 08:46 AM   #5
I did the FCS Remove and clean install. No dice. Here's part of my problem details. I'm off to post them on Apple as well. Thanks for trying.
Process: DVD Studio Pro [3595]
Path: /Applications/DVD Studio Pro.app/Contents/MacOS/DVD Studio Pro
Identifier: com.apple.dvdstudiopro
Version: 4.2.2 (431.40)
Build Info: DSP-4315400~54
Code Type: X86 (Native)
Parent Process: launchd [251]
Date/Time: 2011-09-28 09:42:42.782 -0500
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 168414 sec
Crashes Since Last Report: 12
Per-App Interval Since Last Report: 399 sec
Per-App Crashes Since Last Report: 12
Anonymous UUID: C39D9740-7833-4AF8-9E66-305602296AB8
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000002b
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
objc_msgSend() selector name: setNeedsDisplay:
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x97a75f87 objc_msgSend + 23
1 ...le.prokit.SnowLeopardPanels 0x1bbe059f _NSProNavDrawLabelColorIndexImpl + 9208
2 com.apple.AppKit 0x91db2e0d -[NSDocument _preparedSavePanelForOperation:] + 430
3 com.apple.AppKit 0x91db1d17 -[NSDocument _runModalSavePanelForSaveOperation:delegate:didSaveSelector:contextInfo:] + 273
4 com.apple.AppKit 0x91daf773 -[NSDocument runModalSavePanelForSaveOperation:delegate:didSaveSelector:contextInfo:] + 388
5 com.apple.AppKit 0x91daf9af -[NSDocument saveDocumentAs:] + 66
6 com.apple.dspinterface 0x0004b7aa -[DSPXProjectDocument saveDocumentAs:] + 140
7 com.apple.AppKit 0x91a91a26 -[NSApplication sendAction:to:from:] + 112
8 com.apple.prokit 0x00489414 -[NSProApplication sendAction:to:from:] + 127
9 com.apple.AppKit 0x91a918d9 -[NSMenuItem _corePerformAction] + 435
10 com.apple.AppKit 0x91a915ca -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 174
11 com.apple.AppKit 0x91a914b6 -[NSMenu performActionForItemAtIndex:] + 65
12 com.apple.AppKit 0x91a91469 -[NSMenu _internalPerformActionForItemAtIndex:] + 50
13 com.apple.AppKit 0x91a913cf -[NSMenuItem _internalPerformActionThroughMenuIfPossible] + 97
14 com.apple.AppKit 0x91a91313 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 336
15 com.apple.AppKit 0x91a85a55 NSSLMMenuEventHandler + 404
16 com.apple.HIToolbox 0x92d83c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
17 com.apple.HIToolbox 0x92d82ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
18 com.apple.HIToolbox 0x92da57f3 SendEventToEventTarget + 52
19 com.apple.HIToolbox 0x92dd1e87 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
20 com.apple.HIToolbox 0x92df6b90 SendMenuCommandWithContextAndModifiers + 66
21 com.apple.HIToolbox 0x92df6b47 SendMenuItemSelectedEvent + 121
22 com.apple.HIToolbox 0x92df6a5d FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
23 com.apple.HIToolbox 0x92dc6160 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
24 com.apple.HIToolbox 0x92dc58bb _HandleMenuSelection2 + 465
25 com.apple.HIToolbox 0x92dc56d9 _HandleMenuSelection + 53
26 com.apple.AppKit 0x91a7ef96 _NSHandleCarbonMenuEvent + 285
27 com.apple.AppKit 0x91a53b46 _DPSNextEvent + 2304
28 com.apple.AppKit 0x91a52dd6 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
29 com.apple.AppKit 0x91a151f3 -[NSApplication run] + 821
30 com.apple.prokit 0x0048c3f6 NSProApplicationMain + 326
31 com.apple.dvdstudiopro 0x0000354d 0x1000 + 9549
32 com.apple.dvdstudiopro 0x00002cf6 0x1000 + 7414
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x9537d382 kevent + 10
1 libSystem.B.dylib 0x9537da9c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x9537cf59 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x9537ccfe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x9537c781 _pthread_wqthread + 390
5 libSystem.B.dylib 0x9537c5c6 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x95384aa2 __semwait_signal + 10
1 libSystem.B.dylib 0x9538475e _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x953863f8 pthread_cond_wait$UNIX2003 + 73
3 com.apple.CoreGraphics 0x92676b7d layer_blit_work_queue_thread + 973
4 libSystem.B.dylib 0x95384259 _pthread_start + 345
5 libSystem.B.dylib 0x953840de thread_start + 34
Thread 3:
Thread 4:
Thread 5:
0 libSystem.B.dylib 0x95356b5a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x953846e1 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x953b35a8 pthread_cond_timedwait_relative_np + 47
3 com.apple.Foundation 0x933d595c -[NSCondition waitUntilDate:] + 453
4 com.apple.Foundation 0x9338e451 -[NSConditionLock lockWhenCondition:beforeDate:] + 279
5 com.apple.Foundation 0x9338e334 -[NSConditionLock lockWhenCondition:] + 69
6 com.apple.dvdbase 0x007e184f -[ThreadSafeQueue headItem] + 47
7 com.apple.dvdbase 0x007e5515 -[MPEGEncoderManager generateMPEG_ThreadProc:] + 165
8 com.apple.Foundation 0x93399564 -[NSThread main] + 45
9 com.apple.Foundation 0x93399514 __NSThread__main__ + 1499
10 libSystem.B.dylib 0x95384259 _pthread_start + 345
11 libSystem.B.dylib 0x953840de thread_start + 34
Thread 6:
1 libSystem.B.dylib 0x953b09c5 nanosleep$UNIX2003 + 188
2 com.apple.Foundation 0x933c15d5 +[NSThread sleepUntilDate:] + 147
3 com.apple.dvdbase 0x007e57d4 -[MPEGEncoderManager checkEncoderServer] + 100
4 com.apple.Foundation 0x93399564 -[NSThread main] + 45
5 com.apple.Foundation 0x93399514 __NSThread__main__ + 1499
6 libSystem.B.dylib 0x95384259 _pthread_start + 345
7 libSystem.B.dylib 0x953840de thread_start + 34
Thread 7:
7 com.apple.dvdbase 0x007e8ad5 -[AIFFEncoderManager generateAIFF_ThreadProc:] + 117
Thread 8: com.apple.CFSocket.private
0 libSystem.B.dylib 0x95375ac6 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x9a9e0c83 __CFSocketManager + 1091
2 libSystem.B.dylib 0x95384259 _pthread_start + 345
3 libSystem.B.dylib 0x953840de thread_start + 34
Thread 9:
3 com.apple.dvdbase 0x00a3d159 -[DVDAssetScheduler mainLoop:] + 201
Thread 10: Dispatch queue: TFSVolumeInfo::GetSyncGCDQueue
0 libSystem.B.dylib 0x953618da __getdirentries64 + 10
1 libSystem.B.dylib 0x95361879 _readdir_unlocked$INODE64 + 78
2 libSystem.B.dylib 0x95361814 readdir$INODE64 + 70
3 com.apple.CoreFoundation 0x9a9741a1 _CFBundleCopyDirectoryContentsAtPath + 1793
4 com.apple.CoreFoundation 0x9a9736f7 _CFBundleURLLooksLikeBundleVersion + 55
5 com.apple.CoreFoundation 0x9a9e3f4e _CFBundleCopyInfoDictionaryInDirectory + 238
6 com.apple.CoreFoundation 0x9a9e3e20 CFBundleCopyInfoDictionaryForURL + 80
7 com.apple.LaunchServices 0x95589b0c FSNodePrepareBundleInfoDictionary + 82
8 com.apple.LaunchServices 0x9557d96a _LSCopyNodeAttribute_DisplayNameIfDifferentFromFSName(LSNodeAttributeStateCache*) + 416
9 com.apple.LaunchServices 0x9557d791 _LSCopyNodeAttribute_DisplayName(LSNodeAttributeStateCache*) + 29
10 com.apple.LaunchServices 0x9557d2ca _LSCopyNodeAttribute + 174
11 com.apple.LaunchServices 0x9557c9e2 _LSCopyItemAttributeForRefInfoWithOptions + 281
12 com.apple.LaunchServices 0x9557c8c3 _LSCopyDisplayNameForRefInfo + 59
13 com.apple.DesktopServices 0x917ff139 TFSInfo::GetDisplayName() const + 257
14 com.apple.DesktopServices 0x91803da1 TNode::GetDisplayName(TUString&) const + 259
15 com.apple.DesktopServices 0x91813a98 TNode::ResolveSharedFileListAliasIfNeeded() + 826
16 com.apple.DesktopServices 0x917fb22b TNode::SynchronizeChildren(unsigned long, TNodeEventPtrSet&) + 4409
17 com.apple.DesktopServices 0x917f9c08 TNode::HandleSync(unsigned long) + 886
18 com.apple.DesktopServices 0x917f985e TNode::HandleSync(TCountedPtr<TNodeTask> const&, TNodePtr const&) + 56
19 com.apple.DesktopServices 0x9184c4ea TNode::HandleNodeRequest(TCountedPtr<TNodeTask> const&, TCountedPtr<TVolumeSyncThread> const&) + 1154
20 com.apple.DesktopServices 0x917f7cbd __PostNodeTaskRequest_block_invoke_2 + 94
21 libSystem.B.dylib 0x9538aa24 _dispatch_call_block_and_release + 16
22 libSystem.B.dylib 0x9537d48c _dispatch_queue_drain + 249
23 libSystem.B.dylib 0x9537cee8 _dispatch_queue_invoke + 50
24 libSystem.B.dylib 0x9537ccfe _dispatch_worker_thread2 + 240
25 libSystem.B.dylib 0x9537c781 _pthread_wqthread + 390
26 libSystem.B.dylib 0x9537c5c6 start_wqthread + 30
Thread 11:
0 libSystem.B.dylib 0x95356afa mach_msg_trap + 10
1 libSystem.B.dylib 0x95357267 mach_msg + 68
2 com.apple.CoreFoundation 0x9a9a130f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x9a9a03f4 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x9a9a6334 CFRunLoopRun + 84
5 com.apple.DesktopServices 0x917efb3d TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643
6 ...ple.CoreServices.CarbonCore 0x9976254a PrivateMPEntryPoint + 68
7 libSystem.B.dylib 0x95384259 _pthread_start + 345
8 libSystem.B.dylib 0x953840de thread_start + 34
Old September 28th, 2011, 09:10 AM   #6
From Crash Analyzer:
ProKit Framework
This crash seems to have been caused by the ProKit framework. A common cause for this crash is a mismatched framework version.
If you upgraded to Snow Leopard from Leopard, you may have still have the Leopard pro user interface elements installed instead of the Snow Leopard ones. If this is the case, you will need to either update ProKit (if an update is available) or reinstall Final Cut Pro from scratch.
Suggested Actions
Update Final Cut Studio and ProKit.
Remove Final Cut Studio and reinstall.
Relevant Line
Report generated by Crash Analyzer in Pro Maintenance Tools
It sounds like you may be affected by this:
ProKit 6.0.1 breaking Final Cut Studio - Digital Rebellion Blog
