23.98 fps opens as 22.52 in QT at DVinfo.net
Final Cut Suite
Old August 7th, 2011, 08:27 PM   #1
I exported an mov file with a frame rate of 23.98 in FCP, but when I use QuickTime to open the file and I go under the movie inspector properties it says the fps is 22.52. To double check that I exported the file correctly I opened it in FCP and checked the item properties and it says it's 23.98.
Why do the fps differ from FCP to QT?
Thanks in advance,
O.D.
Oliver Darden is offline   Reply With Quote
Old August 8th, 2011, 09:42 PM   #2
Re: 23.98 fps opens as 22.52 in QT
Oliver, you're a "Major Player" so you should be well aware we can't help you with that little information.
Are you opening it with QT7 or QTX?
Quicktime X only has a "Movie Inspector" with no "Movie Properties."
Quicktime 7 has "Movie Inspector" and "Movie Properties" windows.
Neither have "movie inspector properties."
So I'm assuming you opened it with QT7 and looked at the Movie Inspector because there seems to be a playback issue, because if it plays fine don't worry about it.
When you play a video with the Movie Inspector open it reports "FPS" (frames per second) and "Playing FPS." Playing FPS is affected by playback ability. If your system can't handle either the size or data rate of the video it won't playback in realtime.
But we can't say what's happening for sure because we don't know what QT version you're using, what OS you're using (Tiger, Lion, etc), what Mac you're using (G4, Quad Core, etc) or what export settings you used (H264, ProRes, etc).
Apologies about being a detail nitpicker, but your computer is a detail nitpicker, and if you don't pay attention to the details you tell us then maybe you didn't pay attention to the details you told it.
I need a shower cause I feel dirty after this post...
Jordan Hooper is offline   Reply With Quote
Old August 9th, 2011, 01:16 PM   #3
Details: Dual-Core 2.66 / Leopard / QT7 / Movie Inspector / FPS: 22.52 / Playing FPS 24. Export settings on the file are: Apple Photo - JPEG, 480 x 270 / 1 Hour in length / 11.18 GB.
I also checked the file on my friends brand new Two 2.4GHz Quad-Core and it reads the same thing (FPS: 22.52 / Playing FPS 24).
Thanks for the help Jordan, sorry I made you feel dirty. lol
update:
I just checked another file on my computer (shot in 24fps) and Movie Inspector reads FPS 23.98 and Playing FPS is 24 which is correct. No idea why it says 22.51 on the other file.
Old August 9th, 2011, 08:03 PM   #4
Sounds like corrupt meta data.
As time consuming as it is you're probably best to re-export the project, depending on who the sequence is for.
First try exporting a non self contained version to save time and to double check that the problem is not with a corrupt FCP project file. Check the frame rate at that point via QT Inspector before converting to a jpeg sequence. If it's fine at that point then use QT to export from that file to your jpeg sequence and everything should be fine.
If the non self contained version reports incorrect frames go back to FCP select everything in the timeline, copy, create a new project, and paste into the timeline. Then check everything again.
Hope it works out... and sorry I was a little snarky in that last post.
Old August 9th, 2011, 09:51 PM   #5
Great info Jordan, thanks! I will try this and report any changes / progress.
