Workflow for transcoding at DVinfo.net
Final Cut Suite
Old April 30th, 2011, 11:06 PM   #1
Can anyone verify this is correct?
Took my footage that was 1080i HDV shot at 30fps and imported into FCP7. It shows up there as 1440x1080 ProRes 422 but I need it to match my 1920x1080 footage so I can do multiclip editing since I have four cams. Two are HVx's and the other two are 60D.
I transcoded in mpeg streamclip for ApplePro Res 422 (LT) at 1920x1080 (unscaled). I checked deinterlace video and interlaced scaling with upper field first. I'm confused as to what I'm supposed to check here for the HV20 & HV40 footage as it was shot in HDV30 1080i. But the 60D's are 1080p aren't they (so I UNchecked interlaced scaling and deinterlace video for the 60D)?
It's in my timeline right now, but rendering. My multicam function is not working after sending it through pluraleyes and back, with their suggested way of making a multicam edit.
I'd love any feedback for any experienced users out there.
Thanks in advance.
Lisa Maxwell is offline   Reply With Quote
Old May 1st, 2011, 10:22 AM   #2
Re: Workflow for transcoding
It's a long time since I mixed any HDV with Canon DSLR footage but from memory all you need to do is set up your sequence settings for the Canon files that have been converted to ProRes i.e. 1920x1080 30fps & then drop the HDV clips on the timeline & FCP will magically make them fit. The HDV files are 1440x1080 anamorphic i.e. they have rectangular pixels that give 1920x1080 on playback.
BTW I used to use MPEGstreamclip but am now a convert to Log & Transfer in Final Cut as it allows you to scrub through the clips & set in & out points. So instead of blindly converting every last second of footage you only convert what you are going to use plus it gives you a chance to review your footage while selecting it.
Old May 1st, 2011, 02:16 PM   #3
But to use the multicam function they have to be exactly the same, so 1440x1080 doesn't cut it. I have to convert it to 1920x1080. I wonder if there's a bug in pluraleyes...will be doing research on it tomorrow.
Old May 14th, 2011, 12:47 PM   #4
I do think there is a bug in pluraleyes because I asked in their forum, but never got an answer and I did a test within the same timeline and it worked WITHOUT pluraleyes. Could not do multi-cam function in FCP 7 with HV20, HV40 and 2-60D's. But PE did sync it up nice! : )
