Nudge Audio less than a frame at DVinfo.net
Final Cut Suite
Old August 16th, 2005, 08:31 AM   #1
Is it possible to nudge the audio tack in FCP by a partial frame? Sometimes when edting music the audio track can be off by just a tiny bit and the sound will reverb, or the picture and sound will be off by less than a frame. This is primarily noticable when editing music videos.
Steve B
Set It off!
Steve Barcik is offline   Reply With Quote
Old August 16th, 2005, 08:45 AM   #2
As far as I know this isn't possible, unless it's a feature in the new version.
Old August 16th, 2005, 09:28 AM   #3
Nudge audio less than a frame.
Is there a possible work around by adding 1/80th of a second to the front of a track? How could that be done?
Steve B
Set It off!
Old August 16th, 2005, 09:33 AM   #4
I don't know, audio just isn't my thing... but they used to include Peak DV which is an audio program with earlier versions of FCP. Now maybe Soundtrack has replaced that? But I think the idea was that you could easily send your audio to the other application, make tweaks like this, then bring it back into FCP.
Old August 16th, 2005, 10:12 AM   #5
Images: 1
I believe it is possible. This exact question came up at the FCPUG meeting in July. Problem is, I can't remember how they demonstrated it. Info should be available in the manual though. Specifically, they wanted to edit audio within a single video frame. If yoiu have FCP Studio, you can always send it to Soundtrack Pro, and sync it up in that application.
-gb-
Old August 20th, 2005, 03:06 PM   #6
you could put a very short delay or echo filter on the thrack, mixed 100% wet. the echo filter lets you set a feedback of 10 milliseconds.
a dedicated audio app would obviously be the better way to do things. soundtrack would be fine.
Nate Ford is offline   Reply With Quote
Old August 26th, 2005, 02:03 PM   #7
Yes, you can change edit points sub-frame. Open the clip in the viewer and then move the scrub bar while holding the shift key down. You can apparently move in 1/100 frame increments. Look in the index under "subframe".
A. J. deLange is offline   Reply
