Viewing m2t files before going into FCP
Hi all,
I'm going through a ton of footage, that will be used to make a reality tv show (may make it on air, or might just make it to web). Either way, I'm reviewing clips by going into their folder, highlighting the clip, and hitting my space bar (using latest Mac OS). a window pops open and plays my clip. If I arrow down, it plays next clip. Hit space bar again, and clip window disappears. They used a number of different cameras, and most of the footage, when I will take into FCP, will have to be changed into Prores. Some of the clips are in an m2t format, and its not allowing me to view in the same manor as described above. Does anyone know of a way, for me to view these m2t files, without having to change every single one of them to prores? I have days on days of footage, and would take up lots of drive space. I just need to view, and decided what is essential and what isn't. Anyone have an easy solution for this? Thanks as always, Jeff |
Re: Viewing m2t files before going into FCP
If you just want to view dailies then MpegStreamclip or VLC will work with m2t. ClipWrap is the best and fastest solutions for wrapping m2t in Quicktime so you can edit as HDV in FCP.
Tim Dashwood |
If you want to continue previewing clips using the same method you describe then Clipwrap is your best bet.
