FCP new installation error at DVinfo.net
Final Cut Suite
Old February 9th, 2011, 12:24 PM   #1
I got a new Mac Pro and installed everything from scratch. FCS and all.
Now when I start FCP I get:
License Error
This installation is not serialized. Please re-install the plug-in with the original installer.
How can I find out which one it is? I used FCS Maintenance Pack to find it but all it tells me that all the plugins are "enabled"
FCP seems to work ok but I leaves me feeling a bit uneasy...
Any ideas? Anyone?
and yes - I went through every single effect plugin to see if the registration was correct - I go no errors...
Oliver Neubert is offline   Reply With Quote
Old February 9th, 2011, 02:12 PM   #2
Some plugins have their own licensing systems (e.g. FxFactory and Red Giant plugins) and those plugins must be installed by their respective installers in order to work. I would recommend removing all plugins by major manufacturers and reinstalling these from scratch, as these are the most likely ones to have a proprietary licensing system.
Remember that you can disable plugins in Plugin Manager to help you narrow down the offending one.
Jon Chappell is offline   Reply With Quote
Old February 9th, 2011, 06:44 PM   #3
The plugin manager tells me that all plugins are enabled. I installed each one with the original installer and entered the licenses.
Just had another very strange issue. I tried to import a ProRes file to a new project: - unknown file... the file was made with compressor.
Old February 11th, 2011, 12:15 PM   #4
actually I take that back, the file was encoded with QT 7.
Compressor didn't work, the "submit" button was grayed out. I uninstalled Compressor and reinstalled it- now it works.
Still have the license error though.
