color corrector 3-way problem at DVinfo.net
Final Cut Suite
Old January 26th, 2011, 10:13 AM   #1
So I'm trying to use the 'color corrector 3-way' filter to crush the blacks in a short film I'm finishing up, and I'm running into the same problem every time I do. I apply the filter to one clip, dropping the black levels and boosting the whites and mids a little bit. I then copy that clip, and 'past attributes' copying the filter to the rest of the clips at the same time. Then I render. What happens next is that the entire film becomes one-tenth the size it was before, and is filled with compression artifacts, both in the sequence *and* as a final, exported .mov file.
I really can't figure out why applying a filter would do that, so obviously I'm missing something. Any ideas?
descantproductions.com cloudgate.tv
Sony and Zeiss, FS700, FS100, A7s, A7rii, RX100MkII
Jem Moore is offline   Reply With Quote
Old January 26th, 2011, 12:07 PM   #2
What video codec are you using? And does this happen if you work in another sequence?
Old January 26th, 2011, 12:47 PM   #3
I'm using h.264, 1920X1080 24p imported straight in from 5d MkII files. I haven't tried another sequence because I'd like to know why just using a color-correction filter is causing such trouble. I must be doing something wrong, so hopefully I can fix it. thanks...
Old January 26th, 2011, 01:56 PM   #4
You need to transcode your video files into ProRes before editing.
David W. Jones
www.joneshdfilms.com
Old January 26th, 2011, 02:26 PM   #5
Interesting, I didn't know ProRes was the only codec that you could use filters on in FCP. I'll transcode them and give it another shot. Thanks...
Old January 26th, 2011, 03:20 PM   #6
It's not the only codec you can use filters on.
David W. Jones
Old January 26th, 2011, 09:50 PM   #7
H264 is a very efficient codec in terms of file size to picture quality but it's a terrible codec to edit with. It is very processor intensive and there are many variants of h264. Final Cut likes QuickTime codecs that have every frame sitting in it's own package not referring to a frame a few frames back. The reaction you saw is a direct result of using a codec that Final Cut doesn't interact well with. Transcoding to ProRes might seem to be a nuisance but the savings in rendering time and computer performance is well worth it.
Old January 27th, 2011, 10:18 AM   #8
That makes sense, thanks for the great info. I've transcoded the clips and everything is going great. I am using clips from someone else's camera, I've not used h.254 before since all my clips are Excam or Prores. Always an adventure. Thanks for the help.
