Log & Transfer Question - Import Settings at DVinfo.net
Final Cut Suite
Old November 30th, 2010, 10:08 AM   #1
Is there any way to save my import settings in Log & Transfer? Every clip I import goes back to the default of 4 audio channels...and I don't want all four channels. Aside from manually changing the audio setting for each clip in the batch, is there a way to save a my audio setting for the entire batch of clips?
Thanks.
Jon Springer is offline   Reply With Quote
Old November 30th, 2010, 04:48 PM   #2
The number of audio channels is handled by the preset you are using. The standard Capture Preset for DV and HD assume two channels. And, those presets are locked against changes. You may want to take a look and see what Capture preset is being used and drill into it's audio settings.
Les Wilson is offline   Reply
