Creating an SD-DVD from HD Source at DVinfo.net
Final Cut Suite
Old October 3rd, 2010, 03:12 PM   #1
I've been working exclusively in HD for the past three years and I'm dumbfounded how quickly I have forgotten how to do the most basic things in SD, or more specifically DVDStudeoPro [which I have avoided like the plague].
I've been creating Blu-ray rushes through "Share to" which also works great for the occasional SD-DVD, a producer just asked me for 10 SD-DVD copies.
I copied the Audio TS and Video TS folders from the SD-DVD I created through the "Share to" process and that didn't work, though it did play in one of my DVD players it wouldn't play on the Mac or PC so I'm guessing this is not the right way to do this.
What is the easiest way to burn 10 SD-DVD's? I don't need to author the DVD, no need for menus or chapter markers etc., just play.
Chuck Spaulding is offline   Reply With Quote
Old October 3rd, 2010, 04:25 PM   #2
A SD-DVD is a ISO 9600 formatted disc, a very old formatting technology. DVD players will not recognize anything else as a DVD disc. If you used the normal Mac disc burning program built into the finder, it's the wrong format for DVDs. You can use the disc copy function in Disk Utility to make identical copies of your first DVD.
Old October 3rd, 2010, 04:38 PM   #3
Video DVDs are NOT ISO 9660.
Video DVDs are UDF version 1.02. Many DVD players will NOT recognise ISO 9660 file systems or any other file systems.
DVD Video MUST be authored using a UDF 1.02 file system (and NOT a later version like UDF 2.0 or 2.5/2.6).
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old October 3rd, 2010, 06:00 PM   #4
Thanks for taking the time to reply, however, both answers are Greek to me. I'm just looking for an easy and efficient way to make copies of DVD's that aren't authored.
I just created them using the "Share" drop down menu so they just play when you insert them into a DVD player.
How do I accomplish this on a Mac?
Old October 3rd, 2010, 09:59 PM   #5
Yes, absolutely correct in one way, I was thinking of an firmware updater disc I had to make for my Sony DVD recorder last week. That was pure ISO 9660 or the recorder would not load the firmware. DVDs are UDF files on top of a ISO 9660 directory. A straight ISO 9660 will not work.
Regardless, learning how to use Disc Utility would be very beneficial. Use it to create a disc image of your DVD and then burn the disc image to create a clone of the DVD. The instructions are on your computer. Programs like Toast do this with less steps but you pay for the ease of use.
Old October 4th, 2010, 01:35 PM   #6
Just in case anyone else needs this information:
This was provided by Jude Cotter at LAFCPUG
• Open DVDSP.
• Make sure you have the correct settings for your desired output and country. If you make changes, start a new project.
• Find the 'Assets' tab at the bottom left.
• Import your footage here with the 'import' button
• Find the 'Graphical view' window' above this
• Select the blue menu button and hit the delete key to remove it
• Drag and drop your imported footage from the Assets tab to the green track 1 box
• Right click on the green box and choose 'first play'. This makes the DVD just start up with this vision
• Burn
Here is a Tutorial of the same process thanks to Strypes at LAFCPUG
DVD Studio Pro | Strypes In Post
This is exactly what I was looking for, fast, easy, and uses the software I already have.
