Exporting QT to add effect in PS, then back to FC. at DVinfo.net
Final Cut Suite
Old July 16th, 2010, 01:48 PM   #1
Greetings.
What is the proper way to export a sequence (say one minute or so) so that I can add some visual effects in Photoshop Extended 5 and then send that back to FC without losing image quality?
I assume that the first step is to export a QT self contained file from FC, then open that in PS, add effect(s), and then use some setting to export that back to a file that FC.
Would I use the animation setting? Let me know if you need more info than I've given here. I assume that not only will I have to render in PS, but also in FC when the file is re-imported.
Your help appreciated.
Jonathan
Jonathan Levin is offline   Reply With Quote
Old July 16th, 2010, 03:14 PM   #2
This really depends on what your original footage is. If it's a lossy codec like HDV, then you're better off using a codec like ProRes or uncompressed. If it's a better quality codec like DVCPro HD, then you can stay in that codec.
Arnie Schlissel is offline   Reply
