probs with color replacement at DVinfo.net
Final Cut Suite
Old July 8th, 2010, 09:33 PM   #1
I've been fiddling around with the color correction tools in FCP all afternoon and I can't seem to change a pale pink dress to white. When I key the pink in the dress, I get more skin than dress so the shift throws the skin tones way off. Suggestions? The idea is to get this pink evening dress to look more like a wedding dress without making the model look like an alien or a zombie.
Keaton Clark is offline   Reply With Quote
Old July 9th, 2010, 08:34 AM   #2
Very difficult to reply without an idea of the image you are working with. can you post a frame grab? Hav you tried working in color?
Kevin Wolff is offline   Reply With Quote
Old July 9th, 2010, 12:42 PM   #3
It sounds as if the color of the dress & the model's skin are very close to each other. If that's the case, you may need to rotoscope the dress- meaning that FCP is not a good choice for this.
you may want to try it in Color, Motion or AE.
Arnie Schlissel is offline   Reply With Quote
Old July 9th, 2010, 08:04 PM   #4
thanks
Yes, this bride has too much of a rosy glow, alas. Will give it a try in Color.
KC
