Multicam edit issue at DVinfo.net
Final Cut Suite
Old June 15th, 2010, 03:40 PM   #1
Multicam edit issue
I've been successfully working with multicam edits for sometime now and lately I've been having a problem I cannot solve: When cutting between angles (in this case, only two), the timeline sort of freezes up and then a catches up after a couple of seconds.
The footage is on an external RAID (0) drive - eSATA and the footage is DV anamorphic. I've trashed settings, played with the unlimited vs. Safe RT settings, all to no avail. I must be missing something simple but cannot seem to find it. I am running an 8-core Mac Pro, snow leopard, and FCP 7 with all the latest updates.
Any readers out there ever have this problem? Any ideas on what is wrong and how to fix it?
Reed
Reed Gidez
Reed Gidez is offline   Reply With Quote
Old June 17th, 2010, 04:13 PM   #2
Have you set RT to unlimited? It may be stuttering on playback - and setting RT to unlimited may fix it.
Also, in FCP user preferences, make sure you don't have "Limited real-time video" checked in the general tab.
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old June 17th, 2010, 05:25 PM   #3
Is the drive close to full?
Old June 17th, 2010, 10:10 PM   #4
Settings and drives
Unlimited has always been checked but I did try it in "Safe" as well with no change. Footage is on an new G_Tech Raid drive but prior to that, drives were only about 30% full.
I'm going to get the last three sequences cut before I trash all and start from scratch. I am wondering if there could be some incompatibility between the two angles like DF vs. NDF time code? Have to take a look at that.
Reed Gidez
