MTS to FCP workflow options.... at DVinfo.net
Final Cut Suite
Old June 11th, 2010, 09:44 PM   #1
Hey guys, Ive got a heap of old files from my PC that are MTS, M2T, AVCHD etc.
What is the best way to get them into FCP?
Folder structure is long gone, so Log and transfer wont work, yeah?
Ive done a couple into Prores, but a 2 gb file ends up 14gb, and takes ages.
Is there a better way?
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old June 13th, 2010, 02:00 AM   #2
Look at mpeg-streamclip, many people use it for cross platform conversions and its free!
Link: Squared 5 - MPEG Streamclip video converter for Mac OS X
- Per Johan
Old June 13th, 2010, 04:19 AM   #3
Check out ClipWrap 2.0 :
ClipWrap
divergent media ScopeBox and ClipWrap Forum at DVinfo.net
Andy Mees is offline   Reply With Quote
Old June 17th, 2010, 02:18 AM   #4
I've heard that FCP 7 can import .mts files directly. Is there any truth to that?
Preston Poulter is offline   Reply With Quote
Old June 17th, 2010, 02:30 AM   #5
No ... maybe FCP 8 :-)
Old June 17th, 2010, 07:15 AM   #6
You can do it in FCP 7, but you have to download the Sony plugin for it to work.
Rickey Brillantes is offline   Reply With Quote
Old June 17th, 2010, 02:50 PM   #7
I tried to find that specific Sony plug-in, but need some help. Can someone give me a link?
Old June 17th, 2010, 02:55 PM   #8
Here you go.
Download Sony Recording Unit RAD Plugin
Old June 17th, 2010, 03:15 PM   #9
I installed that plug-in, but still don't seem to be able to import the .mts files. What am I doing wrong?
Old June 17th, 2010, 03:19 PM   #10
Do not import, use the log and transfer.
Old June 17th, 2010, 03:23 PM   #11
I use Log and Transfer but when I select the file with the .mts files it gives me a warning message that the file contains unsupported media.
Old June 17th, 2010, 03:29 PM   #12
When I connect my Sony CX550V to my Mac, It opens automatic when I use the log and transfer. Are you opening the file from the camera or from a folder? If its already in your system you have to use Mpeg Streamclip or ClipWrap conversion, before importing it.
Old June 17th, 2010, 03:38 PM   #13
Gotcha. I have a Canon Vixia HFS100. It also records in .mts format.
Old June 17th, 2010, 03:53 PM   #14
toast 10 works with pure mts files. L&T in FCP requires the folder structure be in tact.
Old June 18th, 2010, 06:30 PM   #15
so, uhm, just to clarify,
Can you use MTS files WITHOUT the folder structure, and WITHOUT transcoding with this plug in?
