P2 / BM Intensity / ProRes 422 / Low Data Rate at DVinfo.net
Final Cut Suite
Old May 25th, 2010, 01:17 AM   #1
Hi
Recently bought a Panasonic AG-HPX302en (Australia) running FCP 7.0.2
Setting cam to AVC Intra 100 25p
In Audio/Settings I choose the following:
Sequence Preset: Apple ProRes 422 (HQ) 1920 x 1080 25p 48KHz
Capture Preset: Blackmagic HDTV 1080i uncompressed
After I've ingested footage into FCP, the browser is showing that the clip's Data Rate is 13.9 MB/sec
Is this a bit low?
If anyone uses the Intensity card, is there another Capture Preset I should be using or is this FCP's way using ProRes to reduce / compress the footage.
In FCP the drop down window for the Capture Preset doesn't really give me a lot of options, I think the HDTV 1080i 50 is about the best option, but I'm sure that's dropping the data rate.
The BM card is only 8 bit I know, but it's not like I'm using the BM to capture the footage, I use it only to monitor with a 32" Panny LCD TV
That said, I have captured 8 bit uncompressed video via HDMI and a Canon HF 10 and that shows up at a data rate of 99 - 101 MB/sec
Any ideas would be welcome, thanks
Michael
Last edited by Michael Lyas; May 25th, 2010 at 01:19 AM. Reason: Grammer correction
Michael Lyas is offline   Reply
