Final Cut Pro Timecode issue at DVinfo.net
Final Cut Suite
Old July 18th, 2005, 12:51 PM   #1
I just realized that I have timecode breaks all in this video that I am supposed to edit for a friend. My question is: Is there a way to capture all of the video off of the tape without recording it onto another tape so I will have one continuous timecode?
Joseph Ivey is offline   Reply With Quote
Old July 18th, 2005, 01:39 PM   #2
nope. either make a firewire dub, or do it with capture now (no device control) and accept the bad tc.
Nate Ford is offline   Reply With Quote
Old July 18th, 2005, 01:41 PM   #3
No. If you want continuous timecode on the DV tape, you have to dub it.
Running FCP4 and above: FCP4 should be able to capture across timecode breaks without problems (i.e. audio sync). You might run into glitches if you want to re-capture off the DV tape, which may or may not be a problem for you.
Old July 19th, 2005, 03:28 AM   #4
could I capture the whole tape into FCP HD and then export back to tape and get a continuous timecode?
Old July 19th, 2005, 08:27 AM   #5
yeah you could do that. not sure why you'd want to that instead of a dub though. unless you just can't get your hands on another dv device to do the dub.
