Editing audio level inside of clip at DVinfo.net
Final Cut Suite
Old May 20th, 2010, 07:23 AM   #1
Can someone please explain how to edit the audio volume inside a single clip. I don't know the technical name but it is done by using points and dragging them up and down when needed. The groom had a cough and I am trying to lower the volume in certain sections of the ceremony.
This is what I am trying to do.
http://www.kenstone6.net/fcp_homepag...ials_fcp_4.jpg
Stephen Pinchback is offline   Reply With Quote
Old May 20th, 2010, 08:11 AM   #2
In the bottom left hand corner of the timeline, there are 2 small buttons, one looks like a line drawing of mountains. Click on that, it'll open up the adjustment your looking for as a line in the audio. Use the point tool to add points & drag them up or down. You can also bring it into soundtrack & do a noise print of certain unwanted noises, but for a cough, what your originally looking for is probably the best way to do it.
The other little button opens up time remapping.
www.breathedeepproductions.com
Chris Korrow is offline   Reply
