FCP on Macbook (not Pro)? at DVinfo.net
Final Cut Suite
Old April 14th, 2010, 07:55 PM   #1
I need to do lots of file conversion to ProRes format, so I need a Mac. I see a Macbook on CraigsList that I'm considering. Comes with FCP3. All for $800
Apple Macbook 2.26GHz 250GB 4GB
Same model as:
I know it doesn't have firewire like the Pro, but will it actually run FCP?
Jeff
Jeff Dillon is offline   Reply With Quote
Old April 14th, 2010, 09:52 PM   #2
Go Go Godzilla
Images: 15
Technically yes, but since the video card is minimalistic at best and, you have no reliable method for connecting an external HDD for editing (USB is not nearly as stable as FW for editing) you'd be much better off finding a deal on a 15" inch MacBook Pro, either unibody or the previous generation.
Old April 15th, 2010, 08:18 AM   #3
I have FCS running on a current MacMini and it's doing fine. Granted this isn't a heavy lifting system but It certainly can edit. The Mini has Firewire though.
Old April 15th, 2010, 08:30 AM   #4
You can not run Final Cut Pro on a Mac book, It says right on the apple site. And if you could pro res renders would be horrendous.
I run the older Final Cut Pro on my power book, but a friend of mine bought a mac book just to find it wouldn't run FCS 2. Did they change this with studio 3?
Aric Mannion is offline   Reply With Quote
Old April 15th, 2010, 03:01 PM   #5
Actually I found a local 17" Macbook Pro for the same price that already has Final Cut Studio 2 (FCP 6) already installed. Checking it out tonight!
Jeff
Old April 16th, 2010, 02:28 PM   #6
Actually I went with 15" Pro with FCP7. First Mac!
Jeff
