Magic Bullet Looks Won't Launch With FCP 7 at DVinfo.net
Final Cut Suite
Old April 6th, 2010, 05:27 PM   #1
Been trying to get Magic Bullet Looks to work with Final Cut Pro 7 for some time now and have had little (intermittent at best) luck getting the plugin (LooksBuilder) to launch.
Tried launching the plugin every way known to man (dragging the effect from the browser onto a clip in the viewer, double-clicking the effect when a clip is loaded in the viewer, dragging and dropping the plugin from browser directly onto a clip in the timeline, going through the Effects->Video Filters menus, etc.) No one way works better than any other.
Each time it shows up in the filter tab under Video Filters in the viewer window, but it only launches the LooksBuilder window about 20% of the time. Even from there, clicking 'Edit' directly in the Looks portion of the VF tab rarely works.
I've upgraded the plugin, upgraded from 10.5.8 to 10.6.3, upgraded FCP 7.0.1 to 7.0.2, and removed the plugin and reinstalled it in that exact order. I made sure to test the results in between each change.
Called and emailed Red Giant a couple times and have yet to hear a response.
I'm perplexed. Anyone experiencing similar problems or have a potential solution?
Thanks in advance.
-Greg Kiger
Greg Kiger St Louis Mo www.GreenBridgeFilms.com
Sony EX1 / Canon 5Dm2 / Cool Lights / DP1x / Marshall / Oktava / Sanken / Kessler
Greg Kiger is offline   Reply With Quote
Old April 6th, 2010, 10:51 PM   #2
Go Go Godzilla
Images: 15
Did you see this post on their support page? Sounds like this may be your issue:
Red Giant Software: Company - Support - Quick Start : [PS-175] Product does not appear after installation and/or does not function correctly (Mac OS X).
Old April 8th, 2010, 08:47 PM   #3
Hey Robert - Thanks very much we will check it out asap :)
