Capture without Final Cut at DVinfo.net
Final Cut Suite
Old April 5th, 2010, 09:51 AM   #1
Does anyone know of a way to capture both HDV and DV without using Final Cut? I would like to be able to edit while capturing, but for some reason Final Cut still decides to lock you out every time you want to capture a tape, even though systems are more then fast enough to handle both now. Any cheap or free utilities to use, or would imovie work?
Brandon
Brandon Katcher is offline   Reply
