Audio Beeping at DVinfo.net
Final Cut Suite
Old March 22nd, 2010, 12:04 PM   #1
Audio Beeping
I am working on a project where I shot the original files in .mp4, then converted to Apple ProRes 422 in Compressor. When I brought the files into Final Cut and put them in the timeline, the audio would not play. Instead, there is a red bar on the very top of the timeline, and the only audio is a repeating beeping. I am new to Final Cut (obviously), what can I do? Thanks.
“If people don’t occasionally walk away from you shaking their heads, you’re probably doing something wrong.” -John Gierach
Jake McGlothlin is offline   Reply With Quote
Old March 22nd, 2010, 02:14 PM   #2
you just need to hit render all. it happens when your sequence settings are different from the file you dropped in there.
I have a dream that one day canon will release a 35mm ef to xl adapter and I'll have iris control and a 35mm dof of all my ef lenses, and it will be awesome...
Nick Hiltgen is offline   Reply With Quote
Old March 22nd, 2010, 05:39 PM   #3
Nick,
I tried that out and it worked just fine. Thanks for the help, it is greatly appreciated!
