OS X 10.5.8 And FCP 3?
I just broke down and got a G5 running 10.5.8 and when i insert the final cut pro 3 disk it says insert original disk?
Go Go Godzilla
The question is whether or not you have a PowerPC G5 or an Intel version? FCP7 will only run on an Intel box.
If that's not the case, do you have the original FCS retail disks or did you get copies made by someone else? |
#3 | |
Presuming the application is really FCP 3, and not FCS 3 (the current version of the entire suite), it is a much older version of Final Cut Pro (OS 9/ OS X 10.1 era - G3/G4), and it sounds like an attempt to run from an incomplete installation. Otherwise, I suspect Final Cut Pro v3 should have no problem running on the G5, providing you have properly installed the complete application from original and legit installation discs. It may also require that you have Classic loaded onto the system, but I'm not sure of that. (FCP 3 was a version that could run in either OS 9 or OS 10.1, but I don't know if it involved separate installations for both. ) I believe Classic was loaded by default up through the G4 lines, but required user installation with G5 lines, so you may need to install Classic from the original system disc, but again, I'm not sure if FCP 3 requires it to run. -Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?" - Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974 |
Problem solved
Got it figured out had to install an old version of QT that came with FCP to get it to install.
