TV not recognized by Mac at DVinfo.net
Final Cut Suite
Old July 4th, 2005, 06:43 PM   #1
The ATI card in my Mac has two DVI display ports. In the manual, one is listed as single-link DVI and the other is listed as single-link DVI TV out.
So I hook my Dell LCD up to the first port and I hooked a regular television to the second port. I used the DVI-to-VGA adapter that came with the Mac and a VGA-to-s video and RCA video adapter that I came with a Matrox G55 card I had laying around.
Well, you can tell the Mac tries to detect the television because it goes from black to a distorted gray pattern twice before it gives up. It does this same thing when I go to Display Settings and try to detect the monitor.
Just to be safe, I tried both DVI display ports and both the s-video cable and the RCA video cable. Same result: the LCD works fine, but the television is never detected.
Now, I know that the scary link in here is the VGA-to-s video and RCA video adapter, but it shouldn't it work?
Thanks for any input you can give me with the current setup.
Alternately, I would welcome a suggestions for how to turn the DVI (or DVI-VGA adapter) into a usable television signal that the Mac will recognize.
Kelly
Partial Equipment List:
Canon XL2 w/ 20X zoom
Bogen/Manfrotto 516 Pro fluid head
Bogen/Manfrotto 3246 legs
Panasonic PATC7WMS1 7" LCD
PowerMac G5 2.7 GHz
OS X Tiger
2 GB RAM, 400 GB SATA
ATI Radeon 9600
Dell 2405FPW 24" LCD
Final Cut Pro 5.0 Studio
Kelly Wilbur is offline   Reply With Quote
Old July 4th, 2005, 06:44 PM   #2
I also tried two different televisions...a 65" rear projection 16:9 and a 32" tube 4:3.
Kelly
PowerMac G5 2.7 GHz
OS X Tiger
ATI Radeon 9600
Old July 4th, 2005, 07:24 PM   #3
Further troubleshooting...
Just downloaded latest ATI drivers. Same results with either Mac Display Settings or ATI Display Settings. TV still doesn't work.
PowerMac G5 2.7 GHz
OS X Tiger
ATI Radeon 9600
