FCP 3 and os X 10.2.8? at DVinfo.net
Final Cut Suite
Old January 17th, 2010, 10:11 PM   #1
i was just curious if final cut pro 3 would run on mac os 10.2.8?
Matt Fowler is offline   Reply With Quote
Old January 18th, 2010, 12:22 AM   #2
I just looked at the box on my shelf and FCP3 will work with Mac OS 9.2.2 or X 10.1.1 (and I assume v10.2.)
I hope you didn't mean FCS3 because it requires MacOS X 10.5.6 or newer.
Tim Dashwood
Old January 18th, 2010, 03:54 AM   #3
As Tim said, do you mean Final Cut Pro 3, released in 2001-2002 somewhere, or if you are talking about Final Cut Pro 7, which is part of Final Cut STUDIO 3, released in august.
For the last one you at least need 10.5.6.
Mathieu Ghekiere is offline   Reply With Quote
Old January 18th, 2010, 09:00 AM   #4
If it's Final Cut Studio 3, here's the list of official requirements: Apple - Final Cut Studio - Tech Specs and System Requirements
I believe that in some cases it's possible to run it on slightly less than that, but it's "not supported"
Michael Murie is offline   Reply With Quote
Old January 18th, 2010, 09:53 AM   #5
no its just final cut pro 3 and its 8 or 9 years old.
Old January 18th, 2010, 02:38 PM   #6
I can't imagine why not.
From what I've read up on it, it looks like it could run in either OS 9 or OS X (10.1), and although could minimally run on a G3, had some optimized factors for G4, so would probably run fine on any pre-Intel G4 MAC up through OS X 10.4.
I would think it should run fine in 10.2.8.
-Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?"
- Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974
Jonathan Jones is offline   Reply
