Speed Change & Reverse Bug? at DVinfo.net
Final Cut Suite
Old June 30th, 2005, 08:59 PM   #1
I have this problem, that so far has seemed a little random. On some clips in the timeline, when I change the clips speed, reverse the clip, or perform a fit to fill edit, the in and out points of the clip shift to a completely different section of the same clip. I havn't been able to figure out why this happens. I'm using FCP5 on a Dual 2.7 G5, with 3.5GB memory, and OSX Tiger.
Has any one else noticed this problem or found a way to fix it.
Matt Trubac
Matt Trubac is offline   Reply With Quote
Old July 4th, 2005, 01:01 PM   #2
DVCreators.Net
Check out the free Nattress "G Reverse" plug-in http://nattress.com/free.htm
Guy Cochran
Guy Cochran is offline   Reply
