Compressor 50fps to DV conversion: no interlacing at DVinfo.net
Final Cut Suite
Old December 30th, 2009, 12:23 PM   #1
Hi everybody,
I'm doing a DV -> TIFFs -> QT uncompressed -> DV conversion to rotoscope several elements on DV video.
- Original DV is PAL with 50 fields per second
- resulting in 50 TIFFS per second (50 full frames using Compressor's Motion Estimation)
- resulting in an uncompressed QT with 50 frames per seonc
- resulting again in PAL with 50 fields per second.
Everything is working fine, with the exception of the last step: when I tell compressor to take a 50 frames-per-second file and make it into a 50 fields-per-second DV stream, it duplicates every 2nd frame, resulting in 25 frames-per-second video with no interlacing.
Can somebody tell me the proper setting so that compressor makes proper 50 fields-per-second video out of 50 frames-per-second output?
Frederic Garnier is offline   Reply With Quote
Old December 31st, 2009, 08:26 AM   #2
If somebody finds this, here's the solution: In the frame controls tab, I had to change the "output fields" to "lower first".
Credit:
lafcpug Forums :: Compressor - Media Compression and Conversion :: Trying to convert 50p into PAL DV 50i, but getting PAL DV 25p instead
