Adding an Efffect to the whole project / FCP at DVinfo.net
Final Cut Suite
Old December 22nd, 2009, 10:16 PM   #1
How do I add an effect to the entire FCP sequence?
Right now I have to drag and drop it to each clip or copy and paste.
Oliver Darden is offline   Reply With Quote
Old December 22nd, 2009, 10:20 PM   #2
EASIEST way is to load the effect into the Viewer, make whatever changes you want, go to the Timeline, hit SPLAT(Command) A to select all and then drag the effect from the Viewer onto the clips in the Timeline. All clips highlighted will receive the effect.
Old December 22nd, 2009, 10:22 PM   #3
great and thanks for the ninja reply!
Old December 22nd, 2009, 10:35 PM   #4
Crouching Tiger, Hidden Jackass... that's me!
Old December 27th, 2009, 04:01 PM   #5
Yep, but nesting the sequence and applying an effect to it is far more flexible - you can easily adjust the effect afterwards.
Jiri Fiala is offline   Reply With Quote
Old December 27th, 2009, 04:56 PM   #6
That's will work as long as the sequence is without dissolves or fades. Especially with filters that soften the image or change the video levels, dissolves turn into subtly strange transitions.
Old December 27th, 2009, 09:57 PM   #7
I second the nesting advice... or make a new sequence and drag the other sequence into it.
Web Youtube Facebook
Cole McDonald is offline   Reply
