Compressor Settings for Exposure Room at DVinfo.net
Final Cut Suite
Old December 21st, 2009, 03:10 PM   #1
Hi:
I am hopelessly confused by the advise one gets on exposureroom.com for Compressor settings. Does anyone have a set of settings for this site to use in Compressor 3.51
Wedding and Events Videography
www.video-vermont.com
Tim Palmer-Benson is offline   Reply With Quote
Old December 21st, 2009, 06:28 PM   #2
Tim I use Exposure Room and have decent success. You do have to remember it will only run low bit rates. I run Compressor 3.0.5
What video are you trying to post:
Camera?
1080p or i
Bit rate from camera
how long?
Paul Cronin
www.paulcroninstudios.com
Old December 21st, 2009, 06:31 PM   #3
For my 1080p footage from FC I render out full size QT then import into Compressor.
Here are my settings:
1280 x 720
Pixel Aspect Ratio: Square
Frame controls off
Codec Type H.264
Pixel Depth 24
Spatial Quality 75
Min Spatial Quality 25
Key Frame 29.97 (Since this is the timeline it comes from)
quality 100%
Average data rate (3.500 Mbps) any faster and it will not run smooth
Fast Start On
Paul Cronin
Old December 21st, 2009, 08:39 PM   #4
Exposure Room Compressor Settings
Hi:
thanks for the settings. All my stuff is in ProRes 10801, inputted from XHAI's. I have had good success uploading to Vimeo with Ken Stone's Compressor settings for Vimeo, but I know they don't work with Exposure Room so well. I will give your settings a try unless you think I should try something else.
Tim
Old December 22nd, 2009, 06:26 AM   #5
Tim I would start with those setting and play with a 10 sec clip. That way you don't have to wait long to see the results. Good luck and post how it goes.
Paul Cronin
Paul Cronin is offline   Reply
