HDV to ProRes 422 - Page 2 at DVinfo.net
Final Cut Suite
Old November 9th, 2009, 11:14 AM   #16
It's been my understanding that you import HDV to PR, Edit PR, and Export PR for best quality.
Understanding that this uses more hard drive real estate.
This may help you out, starting at post #27. Actually the whole thread is helpful:
http://www.dvinfo.net/forum/non-line...uestion-2.html
Jonathan
Jonathan Levin is offline   Reply With Quote
Old November 11th, 2009, 11:56 AM   #17
I think it depends on your camera, and in my case the Sony FX1 can be captured as HDV and rendered as ProRes. Because it is already compressed as HDV in the camera and capturing it as such offers zero loss of quality.
Check out this thread, specifically Jason Livingston's articulate response.
http://www.dvinfo.net/forum/non-line...hq-vs-hdv.html
This clears up the confusion on my end at least!
Aric Mannion is offline   Reply With Quote
Old November 17th, 2009, 08:41 AM   #18
Jonathan
thats exactly what i do with my sony v-1 hdv. i bring in a final edited prores file into compressor for conversion to mpeg2.
i am told that if you apply color correction and other filters there is a definite advantage to applying it to prores files rather than native hdv files (same applies why people use cineform instead of m2t files on PCs) - it results in a better quality mpeg2 file on the final output to dvd
cheers
Sherif Choudhry is offline   Reply
