Audio problem in FCP5 with HDV at DVinfo.net
Final Cut Suite
Old June 22nd, 2005, 09:21 AM   #1
I am having problems with a full quality .AIF file on my sequence when it is set up for HDV - the audio degrades, cracks, and sounds just awful.
If I change my sequence to another format (i.e. DV/NTSC), the problem with the audio goes away.
Has anyone else encountered this in FCP5 or is this just me?
Bryan
Bryan Suthard is offline   Reply With Quote
Old June 23rd, 2005, 08:05 AM   #2
I believe that you're not alone.
I have the same problem:
http://www.dvinfo.net/conf/showthread.php?t=46664
Doeas anyone know a solution to this?
Hugo
Hugo Pinto is offline   Reply With Quote
Old June 23rd, 2005, 09:56 AM   #3
What is strange is that it appears when I render it out to an H264 format output, the audio sounds better. I am not 100% sure but I will do more tests on it. Even if it works, this makes editing the sound extremely however. I think I may have to call Apple Support.
Old June 24th, 2005, 12:23 PM   #4
It appears that this problem is sporadic since I get it some times and not others. Strange......
Old June 28th, 2005, 01:16 AM   #5
I never run into the same problem, yet.
Kaku Ito is offline   Reply With Quote
Old July 15th, 2005, 06:12 PM   #6
I figured out why this is sporadic for me. If I have audio and no video track on an HDV sequence, the audio sounds terrible. If I add a slug to it, it fixes the problem. I put lots of blank slugs as filler in place of no video in my sequences now.
