Copy files from Mac Pro to PC hard drive at DVinfo.net
Final Cut Suite
Old October 5th, 2009, 11:56 AM   #1
I have a client where I need to put my Convergent Designs files I have converted from .MOV to MXF onto a PC hard drive. Is there software that lets me write onto a PC hard drive from my Mac Pro?
Paul Cronin
www.paulcroninstudios.com
Old October 5th, 2009, 07:56 PM   #2
Go Go Godzilla
Images: 15
Yes, there are a handful. Some are pay-ware and some are free but the task is easily accomplished either way, here's one example:
NTFS-3G: Stable Read/Write NTFS Driver
Old October 6th, 2009, 05:29 AM   #3
Thanks Robert I will check out NTFS-3G. Is that what you use.
Yesterday I also found Macdisk.com.
Paul Cronin
Old October 6th, 2009, 05:48 AM   #4
Purchase an inexpensive external hard drive - open the Disc Utility app on your Mac - format the drive as MS-DOS file system.
You are now ready to transfer files back and forth between your Mac & PC with this external Hard Drive.
Good Luck!
Old October 6th, 2009, 05:55 AM   #5
David,
Are you kidding it is that easy? Makes me feel pretty silly that I did not know that one, but always nice to learn something new every day.
Thank you!
Paul Cronin
Old October 6th, 2009, 07:04 AM   #6
Good Luck!
But note that there's a file size limitation of (I think) 4GB in FAT32 systems. That's not an issue most of the time, but with video files ...
Not a reason for not adopting this excellent suggestion - just something to watch for
Nick Gordon is offline   Reply With Quote
Old October 6th, 2009, 07:34 AM   #7
Thanks Nick I knew that one but it is important to put in the thread.
I will be transferring Convergent Designs Nano files that I convert from .MOV to .MXF and then put the files on the PC HD. Convergent Designs limits their file size to 3.5GB so there is not a problem with the FAT32 4GB limit.
Paul Cronin
Paul Cronin is offline   Reply
