Dividing sequence into 2 DVD's/2 Parts on DVDSP? at DVinfo.net
Final Cut Suite
Old October 2nd, 2009, 12:08 PM   #1
I have a project that ended up being 7gigs.
Is there a way to break the sequence in 2 parts? Part 1 on dvd #1, and part 2 on dvd# 2?
Kevin Ta
Kevin Ta is offline   Reply With Quote
Old October 2nd, 2009, 12:34 PM   #2
Go Go Godzilla
Images: 15
Of course, but there's no automated way of doing this. You'll have to find a natural place to split up the content in your timeline, export part 1 and 2 and then create 2 separate DVD images, Disc 1 and Disc 2 with appropriate menus.
Old October 2nd, 2009, 12:49 PM   #3
Would you mind elaborating on how to do this?
I have the chosen a point to create the break between Part 1 & 2, but I do not know how to actually create the break.
I'm a little unclear on what you mean by export, and create two dvd images? And how do I select the first part to export, when both are on the timeline?
Thank You very much!
Kevin Ta
Old October 2nd, 2009, 11:49 PM   #4
Go Go Godzilla
Images: 15
A DVD authoring app is not a movie editor, so if the movie is too big then you have to go back to your editor and split up the movie into 2 separate parts, and use those 2 new movie outputs to create your 2 DVD discs.
Hope that helps.
Old October 3rd, 2009, 06:40 AM   #5
Of course you could use dual layer DVD-R.
Old October 4th, 2009, 11:33 PM   #6
I will definitley go with the Dual Layer option... 48 hours of compressing ain't gonna hack it for me again. Thanks for all the help!
Kevin Ta
