Capturing tape w/ TC breaks at DVinfo.net
Final Cut Suite
Old June 9th, 2005, 09:12 AM   #1
I want to capture footage from a tape that has timecode breaks. Basically I shot some footage on this tape one day, had to take the tape out of the camera (a Sony DSR-250), then put it back in to record some different footage. So I started recording a few seconds after the last recording with the TC starting at 00:00:00;00. So when I go to capture with FCP and specify an I and O point in the second part of the recorded tape, when it goes to batch capture, it rewinds all the way to the beginning of the tape and captures the wrong stuff. I find the "capture now" way of capturing to be too time consuming. Is there a way to work around it?
www.axiomadvertising.com
C. Byrne is offline   Reply With Quote
Old June 9th, 2005, 10:22 AM   #2
try batching what's before the break and what's after the time code break separately. when you're done capturing the first stuff, fast forward until you get past the break and the TC resets.
alternatively, you could use the "capture clip" instead of capturing now or batch capturing in fcp.
Jon Wong is offline   Reply With Quote
Old June 9th, 2005, 12:08 PM   #3
You could dub the tape. The dub will have continuous timecode.
For archiving this may be advantageous.
2- Next time, use the end search feature on your camera?
Old June 9th, 2005, 12:27 PM   #4
But the end search feature no longer works once you take the tape out of the camera. This is what the Sony tech guy told me. It makes no sense to me because my piece of crap consumer camera at home can find the "end" on any tape I throw in it. A serious frustration for a camera that costs 6 times as much.
