time codes from vhs
Hello all
This may be a bit basic but I have a vhs video, that I need to get into my computer, the problem is that it is time coded across the top middle of the screen. Is there any way of removing it as i bring it in to the computer? Or do I have to go back to the base source? thanks in advance Lee |
Lee,
Sounds like what you have is a 'window dub'. Someone has given you a copy of the original source, and burned a timecode onto the screen for reference puposes. No, it can't be removed. It's now part of your image. (IF I understand you correctly.) Your only choice is to 'enlarge' the image so that the code is off screen. (Most NLE's will have a way to do this). But you will suffer some overall image degredation. Otherwise, it's get hold of the original source tapes. |
thanks Richard I guest as much.
