Looking for a keyboard shortcut at DVinfo.net
Final Cut Suite
Old April 9th, 2005, 03:05 PM   #1
Guest
Posts: n/a
I am trying to find the keyboard shortcut, if there is one, for inserting a cut in a clip on the timeline similar to what the blade tool would do but without having to use the mouse and change tools. In Premiere you used to be able to do this, I am sure there is a way in FCP but I am unable to find it - Any suggestions?
Old April 9th, 2005, 04:13 PM   #2
Why do you want to cut the clip? Is it to insert a new clip (insert edit "F9")? Delete part of the original clip? (Ripple, Roll, Slip, Slide?) The keyboard command for the "Blade" tool is "B". It doesn't take very long to hit "B", then click, then hit "A" to return to the selection tool (pointer).
There might be a better way to accomplish what you're trying to do but I don't know what you're trying to do exactly.
Rhett Allen is offline   Reply With Quote
Old April 9th, 2005, 05:03 PM   #3
Control-V should do the trick.
Nicholi Brossia
Nicholi Brossia is offline   Reply With Quote
Old April 11th, 2005, 06:22 PM   #4
Guest
Posts: n/a
Nicholi,
Thanks that is a huge time saver! Exactly what I was looking for.
Old April 17th, 2005, 09:27 PM   #5
Originally Posted by Jerry Ricciotti
Nicholi,
I've modified my keyboard shortcuts to use the slash key (the one with the question mark on top, next to the shift key) to do what ctrl-V does. It saves you a little bit of keyboard effort. I got the tip from Richard Harrington, who did a presentation for my local FCP Users Group.
Murad Toor is offline   Reply
