iMovie questions - Page 3 at DVinfo.net
Final Cut Suite
Old February 1st, 2003, 07:26 AM   #31
Retired DV Info Net Almunus
Do they require Jaguar?
John Locke
SursumFilms.com
John Locke is offline   Reply With Quote
Old February 1st, 2003, 10:39 AM   #32
Warden
iMovie and iPhoto require 10.1.5 or later. iDVD (not free and not available by download) requires 10.1.5 or 10.2.2 or later. Some people are having problems, some are not. If you don't want to experience a problem or two wait for the first or second update. All the bugs are usually fixed by the second update (at least for newer machines). That is the nature of software, especially when it has been rewritten (it's Cocoa, not Carbon).
Jeff Donald
Carpe Diem
Old February 27th, 2003, 11:24 AM   #33
Ben Bruno
Posts: n/a
iMovie...question about still pics
I am using iMovie right now until I can get my hands on FCP. Here is my question. I have some photoshop images that I want to import into iMovie. The resolution is fairly high in PSD..why does the image look so crappy when I import it into imovie? Is there any way to change that? OR does anyone know the recommended resolution to import stills?
Old February 27th, 2003, 11:37 AM   #34
Warden
This thread may be of interest as well as these tutorials.
Jeff Donald
Carpe Diem
Old March 17th, 2003, 02:58 PM   #35
Capturing in imovie then importing footage to Premier
Hi,
I have a break in timecode for about 8 min. of footage. I was wondering if I can capture in imovie and then import my footage into premier? I've heard you can have dropped frames doing this. Does anybody know for sure if this will affect footage in a negative way? thanx a lot in advance.
-Kris
Kris Durkin is offline   Reply With Quote
Old March 17th, 2003, 06:16 PM   #36
Warden
Just capture in separate clips and avoid the break. You can import iMovie into FCP, I would assume Premiere can import iMovie footage also. Try a small clip.
Jeff Donald
Carpe Diem
Old March 18th, 2003, 04:44 AM   #37
RED Code Chef
Premiere can import QuickTime DV files. So if iMovie can create
those Premiere should not have any problems importing the file
(it seems to support most of the QuickTime codecs...)
Rob Lohman, visuar@iname.com
Old April 7th, 2003, 06:20 PM   #38
Warden
Need an alternative to Apple's iMovie?
This was just announced at NAB. It's not free, but less the Final Cut Express
Jeff Donald
Carpe Diem
Old May 16th, 2003, 08:03 PM   #39
imovie to idvd audio sinc problem
This is the problem I'm having with Imovie 3 and IDVD 3. When in Imovie the audio matches the mouths of the people talking perfectly. When I encode using IDVD and play back the finished product the audio goes out of sinc looking like a Godzilla movie with the people moving their mouths and the audio not matching. Any ideas on how I can fix this or why it's happening?
John Dimasi is offline   Reply With Quote
Old May 16th, 2003, 08:12 PM   #40
Warden
This is actually a known issue and a fix is in the works, I read. I understand that a fix involving extracting the audio works for some people and not others. You can read about it here in the Apple Discussions.
Jeff Donald
Carpe Diem
Old May 16th, 2003, 08:15 PM   #41
Thanks Jeff!
Old May 30th, 2003, 12:12 PM   #42
Hi8 PAL, MiniDV NTSC and iMovie 2...?
What do people think about this:
I have a Hitachi Hi8 PAL camcorder, a Sony dsr-pd-150 NTSC camcorder and iMovie 2. Is it possible to use the pd-150 as a DV bridge between my Hitachi camcorder and iMovie 2 to import and eventually edit my Hi8 PAL footage?
Thank you.
Stelios G.M.
Stylianos Moschapidakis is offline   Reply With Quote
Old May 31st, 2003, 11:23 AM   #43
Anyone?
Stelios G.M.
Old June 3rd, 2003, 04:23 PM   #44
iMovie 3.0.3 released
There is also an update to iMovie available on the Apple web site. It works with the new version of QT. Early reports are hopeful that at least some of the nuisance issues may be solved...
Jeff Price
Flickerflix Nature Videos
flickerflix@yahoo.com
Jeff Price is offline   Reply With Quote
Old June 7th, 2003, 04:12 AM   #45
I don't think it's possible because when it goes into the NTSC camera it's going to become distorted, I suppose maybe if you change your deck settings so that your NLE thinks that it's pulling in from a PAL deck instead of an NTSC deck it would be possible.
Nick Hiltgen is offline   Reply
