Importing 1080i from z-1 to i-movie at DVinfo.net
Final Cut Suite
Old February 21st, 2005, 03:00 PM   #1
I am trying to import footage shot on the z-1 in 1080i to imovie. However after about 2 sec the importing stops and it seems as if the computer cannot handle the load. Its a 17 in g4 powerbook 1gz.
Is that normal?
Thanks.
Hellmut Issels is offline   Reply With Quote
Old February 21st, 2005, 10:41 PM   #2
Helmutt, is yours the latest powerbook? Man am I in trouble! I hopethat's not a cpu slow problem! How much ram do you have?
If you don't believe in your film, no one else will.
Sergio Perez is offline   Reply With Quote
Old February 22nd, 2005, 04:11 AM   #3
I have 1 gig ram
I have 1 gig ram but it is not the latest powerbook. It was one of the first 17 inch with 1 GHz speed.
I sure hope there is a solution to this problem.
Any advice highly appreciated.
Thanks.
Old February 22nd, 2005, 07:32 AM   #4
I have a 15" 1Ghz powerbook G4 and it works OK (slow, very slow ;) but ok. So I guess yours should too!
Eric Bilodeau
video SFX,DOP
___________________
http://www.fictis.net
info@fictis.net
Eric Bilodeau is offline   Reply With Quote
Old February 22nd, 2005, 07:40 AM   #5
very slow
Eric,
What is slow? The clip you are importing plays at recording speed or not?
When I import the clip plays at normal speed at first then slows and stops completley after about 2 seconds.
Thanks.
