Cant export a good quality video from FCP at DVinfo.net
Final Cut Suite
Old December 21st, 2004, 09:45 PM   #1
Ok, im still having the same problem I had expressed a while back. I have created an edited short in FCP4. Anytime I export it to a video file...example quicktime conversion, the picture is very pixellated. I was told to do it in mpeg2 form, however that is not an option when I got into quicktime conversions and look under the tab. There are plenty of options including mpeg4 but no 2. Also if I go to use compressor, it acts as if it were pulling up the compressor but nothing happens...you know that phantom window outline that springs open but there is nothing there.
Can someone help me? I would like to get this into a file to use on a dvd that just as decent quality when watched on a tv.
Ryan Wachter is offline   Reply With Quote
Old December 21st, 2004, 10:26 PM   #2
You can use iDVD or DVD Studio Pro to turn your FCP video into a dvd. They have their own MPEG-2 compressor. If all you want is a DVD then that is the way to go. (if you have toast 6 you can use that as well)
Mark Sloan is offline   Reply With Quote
Old December 22nd, 2004, 02:13 AM   #3
To add to Mark's post...
You can either use Compressor to export your timeline in mpeg 2 for for DVD SP or iDVD...or simply export as a Quicktime Movie...NOT Quicktime compression. The exported QT movie will be the exact same format as your source footage (DV), and when you bring the footage into iDVD or DVD SP, it will convert it for you.
Shane Ross is offline   Reply With Quote
Old December 22nd, 2004, 09:53 PM   #4
Thanks for your help so far. Ok i went and had everything exported out of FCP with quicktime movie. Although when watched I still saw the lines(pixelated only with horizontal lines) but figured maybe that wont end up on the dvd. So I took that into dvdSP and did build and burn and it said formatting failed. Could this be due to an incompatible type of dvd-r I am using?
Any ideas would be helpful.
I am using a plextor dvd burner and the dvd-r's are verbatim.
Old December 24th, 2004, 11:09 AM   #5
anybody?
lastwachter.com
Old December 24th, 2004, 11:58 AM   #6
Did you try it only once? Did it attempt to convert and burn or did it freak out at the very beginning?
Open your FCP movie in QT, goto Window->Show Movie Info and tell us what it says. Maybe the export isn't correct.
Old January 1st, 2005, 09:30 PM   #7
Sorry for the delay, i was on vacation and had no way to write.
OK it says
Carbon Copy
Format DV/DVCPRO-NTSC, 720x 480, Millions, Integer (big endian), Stereo, 4800Hz. 16bitz
Movie: FPS 29.97
Data size: 1256 MB
Data Rate: 3.6 MB/Sec
Current 00:00:00;00
Duration 00:05:47;19
Normal size 720x480 pixels
Current size 720x480 pixels.
No it takes a while before giving up, but it doesnt get past the first stage, intializing or whatever it is...
Thanks for your help I sure could use it.
lastwachter.com
Old January 2nd, 2005, 08:49 AM   #8
Dont give up on me now!
lastwachter.com
Old January 2nd, 2005, 11:51 AM   #9
I don't have DVD SP, so I really couldn't tell you what else to try in that realm. Have you tried iDVD to see if it is the file or the program?
Old January 2nd, 2005, 12:12 PM   #10
If using Final Cut Pro, make sure you are exporting as "QuickTime Movie" NOT Using "QuickTime Conversion".
In FCP, as opposed to FCE, the export choice for a self containe FCP move is labled "QuickTime Movie" or maybe just "QuickTime". There is another choice labled "Use QuickTime Conversion" or something to that extent. That is what you DO NOT want to use.
If using Final Cut Express, export as "Self Contained Movie" with audio and video, not a reference movie.
In iDVD preferences make sure you have priority for High Quality selected rather than Priority for Speed (Not sure if it's worded that way though). That is the only way to change the bit rate in iDVD.
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply With Quote
Old January 2nd, 2005, 10:20 PM   #11
I am using FCP and have used Quicktime movie not conversion...
lastwachter.com
Old January 3rd, 2005, 03:33 PM   #12
The specs on your exported file look correct. So I would assume it is something with DVD SP, but try iDVD to see if it will work the file or not.
Old January 4th, 2005, 03:49 PM   #13
I just burned it using toast and it worked. The problem must then be with settings in DVDSP itself...anyone have any ideas?
lastwachter.com
Old January 4th, 2005, 09:38 PM   #14
I exported a FCP sequence to Quicktime, (no conv.) and it is 5:52 long, 1.24GB, very similar to what you rec'd. Imported it into iDVD, to verify quality. iDVD was set for Best Quality. On my laptop, the QT movie looks slightly pixelated, but only on the horizontal. On the TV after burning a DVD, picture quality was excellent.
Are you watching the QT movie on your system when you see the pixelation?
What version of DVD SP are you using?
Joe Matiacio is offline   Reply With Quote
Old January 5th, 2005, 09:22 AM   #15
The horizontal pixelation is most noticable when taking it onto a larger screen such as my television set.
The big problem however is getting SP to work. I have an entire dvd menu set up waiting to burned. It is version 2.
lastwachter.com
