A simple edit, no? at DVinfo.net
Final Cut Suite
Old December 6th, 2004, 09:01 PM   #1
A simple edit, no?
I'm new to FCP and have a question.
I may get a gig doing what should be a simple re-edit on a corporate video, in which case the company would hand me a promotional video on dvd (i.e., a previously completed project) and ask me to insert some stock footage in 2 or 3 places, with some music over the stock footage.
I should be able to take the dvd and capture it with FCP just like any other recorded media, correct?
Then I capture the stock footage, insert it into the timeline and, voila! I've got a re-edited promotional video (dvd, actually). Yes? No?
In other words, I'll re-edit a once-completed project without using the digital master.
Any thoughts?
Kevin Hodes is offline   Reply With Quote
Old December 6th, 2004, 09:31 PM   #2
You cannot really caputer a DVD into FCP or any other NLE without doing one of 2 things 1) play the DVD in a player and use analog outputs to a analog/firewire converter and capture to FCP with some degradation of signal or 2) rip the DVD files to get them raw MPEG2 -> DV using something like this: http://www.alfanet.it/squared5/mpegstreamclip.html
Either way, using the original master footage will give you much better quality. In the end, once you create a DVD of the footage, you've lost some quality due to compression so you are better off going with the originals most often.
Mark Sloan is offline   Reply With Quote
Old December 6th, 2004, 09:53 PM   #3
Thanks, Mark, I was afraid of that -- that degradation would be an issue. I'm not sure of which format the video was shot except that it's digital. If they shot in mini-dv or dv cam, I'm good to go.
Thanks again.
-Kevin
Old December 10th, 2004, 04:08 AM   #4
check out the program dvdxdv, it'll do what you want
Alan Tran is offline   Reply With Quote
Old December 10th, 2004, 08:56 AM   #5
Do you have personal experiance with this?
It seems an awesome answer to some archive, re-edit,time consuming problems I sometimes have.
Gary Chavez is offline   Reply With Quote
Old December 11th, 2004, 02:59 AM   #6
yeah it works perfectly
there is a demo version out there, it puts a nice watermark right in the middle of the screen :-P
Old December 14th, 2004, 02:05 AM   #7
Thanks Alan. :-)
