exporting to 2MPEG program? at DVinfo.net
Final Cut Suite
Old November 1st, 2004, 12:12 AM   #1
Is there another program that I can use to take my uncompressed FCP footage and export it to an MPEG2 for use on a dvd so that it will look decent on a television. My version doesnt seem to have that option of FCP, no matter how many times I reload it or DVDSP.
Ryan
Ryan Wachter is offline   Reply With Quote
Old November 1st, 2004, 06:18 AM   #2
I've found BitVice form http://www.innobits.se to be excellent.
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply With Quote
Old November 1st, 2004, 07:22 AM   #3
Warden
Some people use Cleaner. What version of FCP are you using?
Jeff Donald
Carpe Diem
Old November 1st, 2004, 09:11 AM   #4
I'm using final cut pro 4 and when i go to export>quicktime compression(or whatever exactly it says) I get about 12 options to choose from including MPEG4 but MPEG2 is not in there...
Old November 1st, 2004, 03:53 PM   #5
Have you tried exporting using "Compressor" Ryan
Andrew Hogan is offline   Reply With Quote
Old November 1st, 2004, 04:53 PM   #6
Im having trouble with that as well. For some reason it wants a serial number but wont take the one for final cut pro. They both came together, i dont understand it.
Old November 1st, 2004, 05:16 PM   #7
Did you upgrade from FCP3? maybe it wants that serial number...
Old November 1st, 2004, 06:32 PM   #8
I dont know what has changed but it is no longer asking for a serial number...I tell you what sometimes I think this mac is purposely trying to drive me insane.
Ok, obviously I am new to compressor...what is the best way to compress a fcp movie so that it will look good and not be pixelated on a tv?
Old November 1st, 2004, 06:49 PM   #9
There are lots of Presets in COMPRESSOR.
There are some with higher quality for shorter movies and lower quality compression for long movies (if you are trying to fit it all on a 4.7GB DVDR. Also there are some presets for NTSC, PAL, widescreen,4:3 etc etc so find the one you need and also remember you need to also use it to create your PCM 48khtz audio track.
You can also tweak the presets and save the new preset so you can use it easier next time.
Old November 1st, 2004, 09:03 PM   #10
Ok, im a little confused. I pull out the sequence I want to use, i go to export>using compressor and nothing happens...with or without having compressor open as well. When I start messing around with it, it seems that I need to already compress it with quicktime compression or compressor wont even acknowledge it...doesnt that defeat the purpose?
Old November 3rd, 2004, 06:35 PM   #11
Right, Compressor does the compressing not quicktime. Open your FCP project, open the sequence you want to export. Have the playhead at the start of the sequence and choose: File, Export, Using Compressor..
Compressor will then open automatically. Then choose your preset and "submit" or OK (can't remember the name of the button)
Old November 4th, 2004, 08:12 PM   #12
Yea, thats what I do and it sets up like compressor is opening, but then nothing happens. It wont open. So when I open compressor and go to submit as to compress it, it wont give me the option of choosing the uncompressed sequence...only the one that was already compressed using quicktime...the icon is half fcp slate with a quicktime icon in the middle...thats the only time it will let me do it.
Old November 6th, 2004, 02:16 AM   #13
Thats strange, I've never had that problem. Have you tried the normal fixes like repairing permissions etc?
You could try to export out of FCP as Animation quality Self contained QT movie and then import that into Compressor. But I haven't tried doing it this way as its an extra step that shouldn't be necessary.
Sorry but I think thats all I can suggest.
The probs you've been having with MPEG2 exports and Compressor shouldn't be happening either.
I would hate to suggest the following but would probably do it to my Mac if I couldn't get everything to work as it should.
Restore the Mac and reinstall everything else
Old November 6th, 2004, 08:20 PM   #14
Yea, it might have to come down to that...again.
Ive repaired the permissions before but forget entirely how to do it. Can you refresh my memory?
Old November 7th, 2004, 01:42 AM   #15
In your Applications/Utilities folder open Disk Utility
select your start up Hard Drive and then in the First Aid tab click "Repair Permissions"
