external monitor at DVinfo.net
Final Cut Suite
Old October 16th, 2004, 06:41 PM   #1
external monitor
im not able to get this to happen. g5 fcp4. xl1s.
im seeing the 'dv in' in vcr mode and have fcp4 set to send video apple firewire ntsc 720/480.
seeing no playback in the viewfinder, or on my tv (connected via rca)
is there something more to this?
Heath Hays
MGD Productions
Heath Hays is offline   Reply With Quote
Old October 17th, 2004, 07:13 AM   #2
Hello Heath,
Have you tried rebooting FCP while the camera is left on in VCR mode?
cheers,
Peter
Peter TK Lee is offline   Reply With Quote
Old October 17th, 2004, 11:31 AM   #3
make sure you have it set to view>external video>all frames or command-f12.
Greg Wolfinger is offline   Reply With Quote
Old October 18th, 2004, 12:34 PM   #4
It should appear on your Viewfinder, but I believe the XL1s does not support pass-through so you won't be able to get it to a TV directly from your computer using the XL1s as the converter. Double check your manual or go to the Canondv.com website...
Mark Sloan is offline   Reply With Quote
Old October 18th, 2004, 07:00 PM   #5
Wow...not with the XL1? I can with my GL1.
Shane Ross is offline   Reply With Quote
Old October 19th, 2004, 02:28 PM   #6
gregs answer was what i needed. THANKS!!
heath
Heath Hays
MGD Productions
Old October 19th, 2004, 03:06 PM   #7
Guess I was wrong! I always use another camera as a deck anyway... but now I know I don't have to...
