what final cut format at DVinfo.net
Final Cut Suite
Old August 25th, 2009, 11:51 AM   #1
Did a film several years ago in SD. Have mini dv of cut. Want to replace music and reissue for DVDs and screenings. What format should I use in FCP -- Prores? I know that would mean losing top and bottom frame in 16x9
mg
Milton Ginsberg is offline   Reply With Quote
Old August 26th, 2009, 11:35 AM   #2
If its already in DV you should edit in DV. I wouldn't recommend letterboxing SD footage, the lose of resolution would yield poor results imo.
Old August 26th, 2009, 12:15 PM   #3
Another vote for editing in DV IF you don't plan on making drastic changes to the VISUALS (you mention audio changes).
