e-Mac for FCP or FCExpress at DVinfo.net
Final Cut Suite
Old July 18th, 2004, 11:40 AM   #1
Anyone here use Final Cut Pro or Express with an eMac? I plan on getting the Express soon and wonder how it would perform on my eMac.
Linda Schodowsky is offline   Reply With Quote
Old July 18th, 2004, 11:58 AM   #2
I use FCP on a G3 iBook 800 and it works great! A 1.25 gHz eMac will run it even better. As a matter of fact I plan to get am eMac as well. You can get a refurbished 1.25 gHz with Super Drive for $849 at the Apple Store.
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply With Quote
Old July 18th, 2004, 03:20 PM   #3
I'm using 4.5 on a 1.25 ghz eMac with no problems. I use two firewire drives for capture and render (giving me about 200 gig).
A couple of months ago I used a 700 mhz eMac with Final Cut Express and never had any problems with that setup either. But the renders are faster with the 1.25 ghz.
Jeremiah Hall is offline   Reply With Quote
Old July 18th, 2004, 03:25 PM   #4
Thanks Jeremiah...
That's good to know. My eMac only has 700mhz.
Thanks Dave... that is where I plan to shop when I make my next upgrade!
Old July 23rd, 2004, 06:01 AM   #5
Just wanted to add that I use FCE on an emac with superdrive...and I'm really happy with it!!!!!
eMac's rule!
Dennis Parker is offline   Reply With Quote
Old July 23rd, 2004, 06:12 AM   #6
I can't wait to get my eMac. They are great machines and pretty much put to rest the "Macs are too expensive" misconception.
Old July 23rd, 2004, 06:21 AM   #7
I've run FCE on an eMac 800 w/Superdrive and 512MB RAM for almost 2 years now: never had a problem (although rendering composite images can take a bit longer than with the newer, faster machines).
What I've found helpful is to have the application on the startup drive, and the video and media stuff on a second drive. That way you have two drives working in concert for rendering and playback.
Mark Whalen is offline   Reply With Quote
Old July 23rd, 2004, 11:57 AM   #8
Thanks guys...
My eMac originally came with only 128 ram... I've since upgraded it to 384 ram... still a bit slow. And, as I said.. it's processor is 700mh. I don't have a super drive, so I have to add that on. My mac is the older versin of the eMac.
It's good to know these things. Before I buy FCE, I will need to add on a drive, at the very least. Thanks again!
Old July 24th, 2004, 08:10 AM   #9
You might also want to max out the ram. I was running my first machine with 768 megs, then maxed it to a full gig and got better results from rendering and playback.
It's nice to know I'm not the only one running FCP and DVDSP on an eMac.
Old August 2nd, 2004, 02:13 PM   #10
I used an eMac in a FCP workshop a few weeks ago. Rendering was time consuming, but thats coming from a dual G4 user...
Matt Elias is offline   Reply
