URGENT...FCP serial number question at DVinfo.net
Final Cut Suite
Old July 15th, 2004, 08:24 AM   #1
I'm on the road, in the middle of a project, and I've had to remove FCP 4 due to some problems on my Powerbook. I'm trying to install it again with the original DVD's, but it says I need to have the info from the "Installing your Software" book's front page. I have the serial number and product authorization code with me, but not the book.....what do I need to get this to work?
Thanks!!!!
Krista McCutcheon is offline   Reply With Quote
Old July 15th, 2004, 08:50 AM   #2
Warden
You need a serial number. If this isn't working call Apple Care, 1-800-MY-Apple, there may be a charge for their technical help. Have you deleted all the FCP files? Exactly what does the error message say? What happened to the Powerbook, that may shed some light on your issues.
Jeff Donald
Carpe Diem
Old July 15th, 2004, 09:21 AM   #3
The problems I've been having include the Powerbook (17" G4) crashing at least every other day, with a grey screen that says (in many languages) that I have to hit the Power button to restart. The date and time don't stay set and keep moving to random dates in 1970. It sounds like it's running hot (whirring or fan noises). And FCP will start, but as soon as I go to use it (even opening something) I get, "FCP has unexpectedly shut down. This has not affected other applications." I was also getting this message with other applications randomly. FCP was never working, though. We re-installed OS X and I've just updated it to the latest version. I removed all the FCP files, according to an article on the Apple website.
So, if any of that helps, there it is.
Thanks so much for your time!
Old July 15th, 2004, 09:40 AM   #4
Warden
How much ram is installed and what is the source of it? This sounds like bad ram.
Jeff Donald
Carpe Diem
Old July 15th, 2004, 10:00 AM   #5
We had added a 512 from macsales.com to double the memory, and after troubleshooting over the phone with Apple, took it out to try to locate the specific problem. It's too early to tell if that's solved it, and we still couldn't get FCP to run with just the original memory. I guess we'll put the new memory back in next week and see if the problems return.
Old July 15th, 2004, 11:20 AM   #6
Warden
You may need to do a search to make sure all the FCP files are deleted. Do a search for all files that contain FCP and Final Cut, including hidden files. Then delete all the files. Make sure you're not deleting any media files you need. Then try installing FCP again.
Jeff Donald
Carpe Diem
Old July 21st, 2004, 08:05 PM   #7
Will all the hidden files show up in a search for "Final Cut Pro"?
Old July 21st, 2004, 08:13 PM   #8
Warden
Search using the Apple key and the "F" key. Set it to search for both visible and invisible files. All the files will show up if you search the terms above.
Jeff Donald
Carpe Diem
