Se7en opening title sequence? plugin? at DVinfo.net
Final Cut Suite
Old July 8th, 2004, 12:03 PM   #1
Hi everyone,
Does anyone know how to create the famous Se7en opening? I'm looking to do the titles that jump around randomly. If you know where I can get a plugin please let me know!
Murph
Christopher C. Murphy
Director, Producer, Writer
Christopher C. Murphy is offline   Reply With Quote
Old July 8th, 2004, 01:26 PM   #2
Air China Pilot
Christopher, I don't know about the plugin but the director of the title sequence, Kyle Cooper, is a serious talent. He is just awesome. Look it up.
http://www.imdb.com/name/nm0178204/
Visit http://www.KeithLoh.com | stuff about living in Vancouver | My Flickr photo gallery
Keith Loh is offline   Reply With Quote
Old July 8th, 2004, 01:45 PM   #3
Kyle Cooper seem like a busy titler! But, the Se7en thing is the only one I can recall from memory.
Murph
Old July 11th, 2004, 10:42 AM   #4
the dvd has a nice section about the titling
shows it layer by layer. as i recall he did it
all optically
Remember, Tuesdays are Soylent Green days!
Patrick MCMurray is offline   Reply With Quote
Old July 11th, 2004, 05:22 PM   #5
The lazy way to do something similar would be to simply create a title and add a "film look" filter to the title clip/slug. Then, set all of the film look attributes (IE: Grain, hair, ect.) to zero. Set all to zero except "frame jitter."
Set the "Frame Jitter" setting to around 85 to 90 and viola.
If you do one letter at a time and set the frame jitter attributes differently, you'll get a cooler effect.
That's just something I came up with while fooling around one day.
Hope it helps.
Jason R. Wood is offline   Reply With Quote
Old July 11th, 2004, 06:08 PM   #6
I think a good solution would be to stabilize the text layer to another layer living behind it.... synch it to some guys shoulder as he stands around and it will randomly move about... I think that was in videography or dv mag or something...
Josh Brusin is offline   Reply With Quote
Old July 13th, 2004, 02:47 AM   #7
I did exactly what was posted above. I used cinelook to give the text a random shake, it worked great. You can check out the results at....
http://www.atomicworkshop.org/films.htm#
its the "Freakshow is Useless" clip.
Dean Bull is offline   Reply With Quote
Old July 13th, 2004, 04:40 AM   #8
Great suggestions! I'm going to try it out...thanks!
Murph
Old July 16th, 2004, 07:57 PM   #9
If you want to see more amazing title sequences, go check out Imaginary Forces. Cooper produced Se7en under them and there are many more amazing sequences in their projects section.
alextaylor.org
Alex Taylor is offline   Reply
