Lumiere HD workflow - Page 4 at DVinfo.net
Final Cut Suite
Old December 31st, 2004, 03:13 PM   #46
MPS Digital Studios
One more problem, when importing the XML file, it gives me "non-critical errors" saying it can't "attach" the media file to the clip.
heath
My Final Cut Pro X blog
Old January 4th, 2005, 02:46 PM   #47
Heath,
It's all resolved right?
Frederic
Frederic Lumiere is offline   Reply With Quote
Old January 4th, 2005, 02:54 PM   #48
MPS Digital Studios
Yes. My mistake was calling the original captured M2T clips:
Amanda Wide Shot
Instead of the proper:
Amanda_Wide_shot
Frederic, can you re-explain how to keep things from going out of sync, audio/video-wise?
Also, everyone, I am creating my MOV files as DV 720 by 480, because I know that in the coming weeks, I'll be able to "online" my cut into 1080i HDV and output to tape with the FX1.
heath
Old January 6th, 2005, 02:53 PM   #49
MPS Digital Studios
Need new help with the 1.5b beta!
I can email whomever can answer this a still from footage captured, demuxed and made into a timeline codec using the 1.5b8 beta of LHD, and a still captured on Final Cut Pro 2 from a digital downconvert via firewire to a DVX100A.
When I did the codec, I chose DV 720 by 480. When I made a still image from my edit in FCP HD, the image is darker and not as clear as the still my friend made in FCP 2 with the digital downconvert (720 by 480).
Is there something wrong with the initial capture, demux or timeline codec processes? I also notice a new beta (1.5b9)--should I try re-capturing that way, or going through the other processes with the new beta?
Again, I'll email those stills to whomever can answer this question!
heath
Old January 9th, 2005, 05:37 AM   #50
RED Code Chef
Well it's called a beta for a reason. So this might be a bug. I would
certainly try a newer beta. I assume the beta comes with instructions
on who to contact if you find problems, follow those guidelines.
The developers needs feedback on such issues!
Rob Lohman, visuar@iname.com
Old February 14th, 2005, 10:54 AM   #51
Question about offline DV editing.
How would graphics work in a DV offline setup?
Wouldn't anything created (either in Motion or Livetype or FCP itself) be the wrong resolution when you online HD?
I'm still learning the process here, so I might be missing something obvious.
Bryan McCullough is offline   Reply With Quote
Old February 16th, 2005, 04:17 AM   #52
RED Code Chef
I'd say you create the online versions for these and downsample
them to your offline resolution for use there. At least that would
be my guess. All original material should be available in the full
online quality. But what do I know...
Old February 16th, 2005, 08:57 AM   #53
That's an interesting question Bryan.
I think if I were gonna do a project like that I would:
1. Create full res HD graphic elements
2. Make copies of elements-add "ol" to the name
3. Resize the copies to fit DV resolution aspect ratio
4. Do offline
5. Before online, rename the original elements and add "ol" to name
6. Online
There are a lot of opportunity for strangeness here, and I think it would only work quick and easily if the DV project is 16x9. I would make sure to do a couple of quick tests first, before I finalized the workflow.
Good Luck!
Sean M Lee is offline   Reply With Quote
Old February 16th, 2005, 04:49 PM   #54
Lumiere...is it worth the workflow?
So, you folks using it, is it worth the time and effort?
Can I expect Z1/M10 output capability soon?
Is the process really as long as it seems like it will be?
Old February 23rd, 2005, 10:00 PM   #55
New Lumiere HD Beta now allows back to Sony Tape
The new beta version of Lumiere HD (Version 1.5b10) now allows encoding of MPEG2 Transport Stream compatible with the new Sony HDV devices, including:
- SONY HDR-FX1(1080i60)
- SONY HDR-FX1(E) (1080i50)
- SONY HVR-Z1 (1080i50/60)
- SONY HVR-M10U (1080i50/60)
Lumiere HD can take any 1440 X 1080, 60i clip (Any codec) and encode it to an MPEG2 transport stream the Sony cameras and deck can receive.
Customers can download the new beta, free of charge from:
http://www.lumierehd.com/beta_download.php
Frederic
Old February 24th, 2005, 06:38 AM   #56
Hi Frederic, I have a valid 1.2 version of Lumiere HD....but, I can't seem to get the betas working. I've tried to activate using the latest number I recieved.
I'm a Z1U owner, so I could be of help with testing it.
Christopher C. Murphy
Director, Producer, Writer
Christopher C. Murphy is offline   Reply With Quote
Old February 24th, 2005, 07:57 AM   #57
Christopher Murhy? Never heard of you...sorry
Just kidding Murph. Send me an email with your S/N
Frederic
Old March 1st, 2005, 08:03 PM   #58
MPS Digital Studios
I believe you already can.
hwm
Old April 8th, 2005, 11:02 PM   #59
Need Help With Lumiere/Laying To Tape
I have Lumiere (yes, the new version), but it converted everything out of sync. No matter how hard I tried to sync the audio, it still drifted. I gave up and purchased FC Express.
Now that I have my project completed (2 hour feature), I need to get it to tape. I need my HDV 16:9 footage resized to 4:3/letterbox and recorded to DV Cam tape.
FC Express has no option for 4:3. FC Pro does. I have output 1 min. test clips to DV Cam and they look "ghost-like" on the sped up motion clips and the regular clips look pixilated (almost like a posterized effect). Any suggestions/solutions?
I used FC PRO to output these test clips. Since Lumiere doesn't have very good instructions, I can't figure out how to lay to tape once I have made an mt2 conversion. Also, is that conversion oly for laying back to HDV or can I lay to DV Cam using Lumiere?
HELP!
Lori
Lori Peters is offline   Reply With Quote
Old April 12th, 2005, 03:34 PM   #60
LumiereHD to Handle JVC's 24P ProHD format
Interesting little tidbit for those interested in the 24P function of the new JVC cam.
Check out Mike's great site, HD for Indies
Scroll a little down the page, it's a few articles down.
the headline reads:
"LumiereHD to Handle JVC's 24P ProHD format"
Luis Caffesse
Pitch Productions
Austin, Texas
Luis Caffesse is offline   Reply
