iMovie 09 to FCP 6/7 at DVinfo.net
Final Cut Suite
Old August 10th, 2009, 12:14 PM   #1
Would like to know if anyone has had success or problems in importing an iMovie 09 project into FCP 6 or 7?
Specifically:
- Capture footage into iMovie utilizing NeoScene.
- Edit project in iMovie (w/NeoScene).
- Transfer finished edited project over to FCP 6/7.
Just curious if this can be done without to many hiccups along the way.
Andrew Clark is offline   Reply With Quote
Old August 10th, 2009, 03:49 PM   #2
It is easy just export XML to Final Cut. The movie will come in as a sequence and then you can cut and paste.
I have found that the new small camera I purchased the Sony XR500V will only give smooth footage imported into iMovie. So then I export to FC with XML and it works great.
Paul Cronin
www.paulcroninstudios.com
Old August 10th, 2009, 04:56 PM   #3
** So I take it that the XML is an export option in iMovie 09...is that correct? So then I would open up FC and import that file....is that how you do it?
** I was thinking of getting that cam too!! How do you like it?! .... Oh and thank you for the informative reply!!
Old August 10th, 2009, 11:38 PM   #4
The XML export option is basically a list of cut points that iMovie gives to FCP which then imports the original files & applies those edits. You are limited to simple transitions & does not export music, titles etc. but can be useful e.g. to do a rough edit on the road on a laptop that would struggle with FCP.
Old August 11th, 2009, 06:25 AM   #5
Yes it is iMovie 09 the latest.
But Nigel is correct I would not use iMovie for editing. I am only using it since FC will not properly import from the XR500V. Once it is in FC I have all of my options when I put it in a sequence not the iMovie sequence that came in.
As for the XR500V the jury is still out. I used it on a job yesterday where the EX1 was the A camera and the XR500V was in a housing in and out of the water. I have not looked at the footage yet.
Paul Cronin
Paul Cronin is offline   Reply
