NLE Mac / Final Cut questions from 2004 - Page 8 at DVinfo.net
Final Cut Suite
Old January 21st, 2004, 12:39 PM   #106
Warden
Most cameras are designed to white balance to white or a neutral shade of grey. Higher end cameras (and to some degree the DVX100) have the ability to use a curve to adjust the color responce.
Some of the squares in the Macbeth card have known RGB values that could be measured with a color picker tool. Then a curve would have to be applied to match those colors and the scenes rendered.
Jeff Donald
Carpe Diem
Old January 21st, 2004, 12:43 PM   #107
Yeah, after a bit of research, it seems as though I would be better off just buying a cheap-o PC running Windows XP. Supposedly, and likely, Macs communicate just fine with XP. As long as I can move files back and forth, I can use the PC and Windows Media Encoder to crunch the video into .wmv files.
I know the two computers can be linked together via ethernet, but is it possible to use firewire? Would the PC mount on the Mac desktop? This isn't really a big deal, I'm just wondering.
Nicholi Brossia
Nicholi Brossia is offline   Reply With Quote
Old January 21st, 2004, 01:52 PM   #108
So, are you saying to create a red, blue and green color/gamma curve based on a sample RGB value on the color card, then create a profile? I've done that in Photoshop. I wasn't aware it could be done in FCP
Brandt Wilson is offline   Reply With Quote
Old January 21st, 2004, 02:06 PM   #109
Warden
You would need to do that in After Effects. Why do you want to use a Macbeth color checker and what issues are you having with color?
Jeff Donald
Carpe Diem
Old January 21st, 2004, 06:57 PM   #110
I'm looking at taking video from telecine sessions and performing an accurate color grade that will represent what the final release print will look like before I have it finalized. I want to be able to previsualize my final grade and make changes on the desktop before getting into the expensive color timing phase.
Old January 22nd, 2004, 12:56 AM   #111
Adding a 3rd HD - Mixing Brands An Issue?
Hey everyone,
I'm looking to add a third HD because I'm taking on a rather large project (35+ hours and counting) and want the room to maneuver.
Right now, I have the stock Apple 80 gig HD that came with my G4 and I added a 160 gig Western Digital Caviar (8meg cache, 7200 RPM).
The question, before I buy a 3rd HD, is: Is there any issue in getting a 3rd HD from another company or should I stick with Western Digital? (Not that WD isn't great; I've had zero problems so far. <knock on wood>) And though I seriously doubt it, is there any issue in jumping up to a 200/200+ HD (Western Digital or otherwise) on this G4?
And of course, any brands that I should stay away from in particular or hover to...in the past, I've heard recommendations of IBM, Seagate, WD. How about Maxtor, etc?
Joshua
Joshua Kopple is offline   Reply With Quote
Old January 22nd, 2004, 03:00 AM   #112
It won't matter at all. I'm using a variety of HD's on my system. I used to be a total Maxtor fan until they were bought and have had a lot of reported problems. But..looking at my portables and G4 system, I've got a mix of IBM, Maxtor, and WD, plus even a Seagate in there.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old January 22nd, 2004, 08:56 AM   #113
FCE2 Capturing Technique
Warning! Total Newbie question...
I just installed FCE2 (eMac 1GHz, 1GB, 80GB), my only experience is with iMovie.
I have about 45 minutes of tape shot at my son's 7th birthday party last week. I want to edit it into a coherent story and add some music, then burn a DVD.
I started to capture it clip-by-clip, but the camera whirr-click-buzz seems to eat a lot of time and put a lot of wear and tear on the hardware.
Should I just transfer the whole tape in one big chuck and then chop it up in FCE2, or is the clip-by-clip transfer the better way to go? How do you usually transfer whole tapes?
Also, i feel really overwhelmed by the complexity of FC, I assume it's not as huge as it seems at first? How long will it take to become reasonably competant with this software? I figure I can spend one hour per day learning it.
Thanks...
dB
Dan Brown is offline   Reply With Quote
Old January 22nd, 2004, 10:42 AM   #114
Hang in there Dan.
Was in your situation 9 months ago. Now I would not go back to iMovie. (even though it is a great programme too.
Import your total footage. It is not worth wasting time and effort selecting clips here and there. (Having batch capture would have helped here but this is not FCP!)
My tip is
Create 2 video tracks
Drag the whole clip (45 Mins) to one of these and drag it over to the right of the time line to give you room to create say a 10 minute movie starting at zero.
Go to the section you want.
Use the blade tool (keyboard b or b+b to cut video and audio) to cut to create a clip
If the snapping to the nearest cut is on (and this annoys you), toggle this setting by pressing "n"
copy and paste (again use AppleC and Apple V)
Place in in the 1st track
Get next clip and repeat
Put this in the 2nd track with a small overlap of the first
You can adjust the boundary by dragging the edges (To get the arrow pointer back at any time, click A)
Repeat this process until you have your movie
The top track will always superimpose on the lower when you play back
Whilst doing this going back and forth, get used to using the z tool to zoom in ans Z+Z twice to soom out.
For transitions, open the transitions and drag to the clip edges you want.
Hope this helps.
Regards P
Sony PDX10 by 2, DRS-11, Dual G5, FCX, DVDSP and Logic Plat.
www.VarsityMusicVideo.com
Patrick Grealy is offline   Reply With Quote
Old January 22nd, 2004, 11:11 AM   #115
Frame size for offlineRT
I have a DV project which is taking longer than I would like to render on dual 2 gig G5.
In the middle of the project I decided that I would try offlineRT, so I exported the clips as offlineRT NTSC and converted the timeline to photoJPEG then I reconnected the DV NTSC media to the exported offlineRT media.
Due to the 320x240 frame size of offlineRT the each of these clips appear to need resizing to 720x480, this seems cumbersome. Do I resize all of the clips then shrink them down again after I recoonect the original DV footage?
I am sure that I am doing something wrong here, can anyone point out what it is?
Paul St. Denis is offline   Reply With Quote
Old January 22nd, 2004, 12:57 PM   #116
Formatting Media Drive between projects? What do you do?
Do you guys all do a quick format of your media drive at the end of one project before starting another? Any advantage or disadvantage to doing it?
And is there any harm to not partitioning your drives (maybe because they're too big - 160gb or 200+gb)?
Joshua
Old January 22nd, 2004, 03:37 PM   #117
Promax recommends IBM drives since they were the most reliable in their experience with thousands of drives. Seagate and WD come #2, and they don't like Maxtor. Generally IBM, Seagate, and WD are fine. Seagates are slightly slower but they are the quietest.
If you want to RAID later then get 2 drives of the same model. Otherwise I'd just get the largest WD/IBM drive you can afford. IBM sold their drive division to Hitachi, so they're Hitachi now.
Old January 22nd, 2004, 03:41 PM   #118
You don't need to partition your drives. It *may* help in reducing fragmentation since fragmentation stays on one partition only, and you can selectively clean up that partition by defragging it or deleting everything on it.
Fragmentation really isn't a problem if you keep only large files on a drive. Some people just quick format their drives when they're done a project so they don't have to worry about fragmentation.
Old January 22nd, 2004, 03:49 PM   #119
That's what I do personally, just format the drive and start all over again!
Old January 22nd, 2004, 07:23 PM   #120
Western Digital Caviar 250gb
Thanks for any input guys. I just went out and bought the WD 250GB 8mb cache HD at Best Buy. $259 + $90 rebates and I had 80 bucks on a gift card. So in the end, it worked out alright for me.
That and I already have the WD 160gb so it just felt right. WD's done alright by me so far. <knocking on wood some more>
