NLE Mac / Final Cut questions from 2004 - Page 74 at DVinfo.net
Final Cut Suite
Old August 8th, 2004, 06:38 AM   #1096
Warden
Do your tapes have time code breaks or did you reuse them? Try capturing after changing your preferences to not stop on TC breaks.
Jeff Donald
Carpe Diem
Old August 8th, 2004, 11:01 AM   #1097
Images: 3
what FCP are you using?
Coordinator Eurovision Asia-Pacific
Andre Bentlage is offline   Reply With Quote
Old August 8th, 2004, 11:03 AM   #1098
Images: 3
lets us know what you figured out please, because thats all this forum about!
Old August 8th, 2004, 11:16 AM   #1099
Images: 3
rendering
we should write poems about it
its the most powerful computerprograms can do
actually its the only work they do
without you
you do the rest
advise
don't render too fast
you have more time to do....
Old August 8th, 2004, 11:28 AM   #1100
Images: 3
Whats the biggest external disk at the moment available?
Old August 8th, 2004, 11:35 AM   #1101
Oh I just dragged the clip from the viewer to the canvas, and when you hold down the mouse it gives you options to insert it. It will insert the clip where the playhead is placed in the timeline, so I had the playhead between the two clips that I wanted to place my clip between.
Matt Elias is offline   Reply With Quote
Old August 8th, 2004, 02:52 PM   #1102
I think it's still 1TB. One Terabyte.
http://www.jigsaw24.com/proddesc.asp?ITEM=X325AGA
But you can get it cheaper,
Jake
Jake Russell is offline   Reply With Quote
Old August 8th, 2004, 03:24 PM   #1103
I am using final cut pro hd. thanks for the help so far, ill give it a try.
have you ever wanted something so bad you couldent stop thinking about it? a car, a girl, a skate trick? thats what this video was to me it started as an addiction but turned into an obsession.
-Adam Johnson
Alex Beaupre is offline   Reply With Quote
Old August 8th, 2004, 04:33 PM   #1104
I'm using the 400 GB model. It's great to have the capability of simultaneous capture on my PowerBook - DV in on FW400 and out to the Big Disk on FW800.
The unit is still new to me, but functioning well so far.
Ron Johnson
Portland, OR
Ron Johnson is offline   Reply With Quote
Old August 8th, 2004, 07:12 PM   #1105
<<<-- Originally posted by Mike Hanlon : Open the Dissolve folder in the Video Transitions folder.
Copy the Cross Dissolve transition to the Favorites folder.
Open the Favorites folder.
Change the name of the cross dissolve copy to something you like.
Double click on the Length value and change the length of the transition to :15.
Put the cursor over the name of your new 15 frame cross dissolve.
Hold down the control key as you click on the name.
Select "Set Default Transition" from the popup. -->>>
I do it, but i can't get it to "stick".
When i got back and check it, it says 1 second again.
Sony VX-1000
G5 1.8 dual
91 Turbo MR2
Ray Echevers is offline   Reply With Quote
Old August 8th, 2004, 10:49 PM   #1106
Hmmmm. I tried the steps I listed before I responded.
When setting the length of the cross dissolve copy you put in the Favorites folder (step 5 in my list), make sure you click on the value in the Length column in the Browser window and set the new length (15 frames in this case). Double clicking on the transition and altering the length in the Viewer doesn't work.
When you say you can't get it to stick, which "it" do you mean?
Mike Hanlon is offline   Reply With Quote
Old August 9th, 2004, 05:46 AM   #1107
<<<-- Originally posted by Mike Hanlon : Hmmmm. I tried the steps I listed before I responded.
When you say you can't get it to stick, which "it" do you mean? -->>>
I did it another way. I did a dissolve in the timeline, then changed it's duration, i right clicked and hit copy, then i just pasted it in the favorites folder, and set it to default favorites, works now.
Sony VX-1000
G5 1.8 dual
91 Turbo MR2
Old August 9th, 2004, 11:25 AM   #1108
slowing down video - not very good results
I'm trying to slow down a background effects clip exporting from Livetype. If anyone out there has Livetype installed and wants to see the clip, its "Canopy" under the Medley category of the Textures section.
Anyway, I want to use this as a background to some title effects for a wedding video, but the clip is too fast for me. I've tried slowing it down in LiveType and again in Final Cut Pro (with and without Frame Blending). None of these has worked very well. They all produce s stuttering video. It plays black slower, but not as smooth.
Does anyone know of a better way to slow down these clips? I've heard that Final Cut doesnt do a great job of it... maybe there is a (free, hopefully) third party filter that will do it?
www.interactiverecipes.com
Chris Wright is offline   Reply With Quote
Old August 9th, 2004, 12:11 PM   #1109
Warden
What are you using to view the effects?
Jeff Donald
Carpe Diem
Old August 9th, 2004, 02:23 PM   #1110
im not sure if this is what you mean, but I'm viewing the final effect in final cut pro as well as on a 14" tv
It doesnt look right on the computer or the TV...
